According to the latest NPS scores GA is now comfortably bottom of the "NSE" table. Of course the timing of the survey probably did them no favours, but they saw significant drops compared to last Spring (due to the seasonal nature of responses this is the best comparator) in overall satisfaction (5%), Punctuality/Reliability (5% and the biggest driver of overall satisfaction), valuue for money (5% and probably also heavily influenced by performance) and cleanliness inside the train (5%).
The cleanliness score I believe may actually be the result of the so-called "deep cleans". The fact that most of these units have not had a refresh in a very long time has meant that we've ended up with these cleans being more successful in some areas than others, thus exposing the true level of ingrained dirt; plus they have caused some of the coverings to come away. It is well-known that an internal refresh will give a massive boost to perceptions of cleanliness. The tired, old stock on GA is obviously seeing the opposite effect.
Oddly the single significant riser is a 5% hike in sufficient room for all passengers to sit/stand (if true means less commuters which could be hitting revenue).
Was winning this bid a pyrrhic victory for Abellio? Struggling on the revenue front, and with a whole host of problems that this stop-gap franchise was not set up to solve, they are in danger of sullying the hard-won reputation that they have gained from Northern and Merseyrail.
