kellogs211
- Joined
- 12 Dec 2007
- Messages
- 9
Is it possible to buy an old HST engine??? Just wondering for my future!!! could try and fit one in a Estate Car!! LOL
Jonathan
Jonathan
Jonathan
I doubt you'd get one into an estate car, more a large transit. Don't forget you aren't just putting the engine in, you are putting inIs it possible to buy an old HST engine??? Just wondering for my future!!! could try and fit one in a Estate Car!! LOL
Jonathan
Errr...I think you'd have trouble fitting a rather large 12 (?) Cylinder Paxman Valenta or VP185 engine into an Estate....
Engine
Turbo
Cooling system
Air inlet
Exhaust system
Fuel tank {4,500 litres /1,000 Gallon}
On an HST, the engine produces electricity to drive axle mounted traction motors, instead of the belt drive of modern road vehicles
Also, you'd need to significantly alter the vehicle suspension to cope with the increased weight.
I hope you've seen the size of the cooler groups...They're frigging massive.
If it was possible, I'd have a car fitted with a Valenta, Brush cooler group, Napier turbocharger and a massive fuel tank (as well as the other bits). Would certainly wake the neighbours up in the morning!
Booths, however, would be the best place to get them. Deep pockets would be rather helpful too...
Bear in mind the HST has capacity of about 79l (?) so guzzles a LOT of fuel which isn't likely to be able to be sourced from Tesco's /Asda's/Sainsburys'/Morrisons' forecourt.
One of those LED scrolling displays with 'Catch Me If You Can' on them too... just to give the wombles a fright as you scream past leaving a smoke screen in your wake!
I like the idea of an EE 12CSVT... hehehe
That's a creation that I've been dreaming of for quite a while now, although I'd be inclined to have the engine mounted in the final trailer and provide power to all axles using a hydraulic final drive.Valenta engined bendy bus would be interesting, only the rear portion would have passengers in.
How big you think them tanks are under morrisons. They hold about 50tonnes in each tank...
