Oldest engines in mainline use
hougtimo
28 Feb 2008
Which dmus currenfly have the oldest engines? What sort of mileages arw they likely to be at?
asylumxl
12 Feb 2009
Hiding in your shadow
I would have thought the HSTs would have pretty vintage engines, but since the Valentas have all been replaced by MTU engines or VP185s, I guess they aren't any longer.
Lampshade
3 Sep 2009
South London
I'd hazard a guess at some of the 150s as they are the oldest DMUs in operation, most Pacers were re-engined in the early 90s.
ChrisCooper
7 Sep 2005
Loughborough
Discounting the 2 (sort of) class 121 bubble cars still in service, the oldest DMUs are the 150s, first introduced in 1984 (the prototypes). If it's got it's original engines then it would be 150001, as 002 was fitted with Rolls Royce and the Perkins engines before getting it's standard Cummins engines. I imagine engines have been swapped around a bit though, including with later classes such as the late 80s 156s and possibly some new build spairs if any really blew up (the NTA855 was being built well into the 90s).
colpepper
17 Jan 2011
West Yorks
Slightly OT but I'd guess some of the first generation DMUs clocked up astronomical mileages on the same power plant, repairs not withstanding.
O L Leigh
20 Jan 2006
In the cab with the paper
Most powerplants get taken out, stripped and rebuilt. I know that's certainly the case with EMU traction motors, and some of those are getting pretty ancient now. The Cl455's use traction motors reclaimed from the second-batch of 4SUB EMU's that were rolling off the production lines during the late 1940's.
O L Leigh
O L Leigh
Wow, I thought the last of the 40's kit had gone with the SUB De-Icers a few years ago! Reminds me of the LSWR underframes that were still to be found in (I think) SAP units in the eighties. You can't beat the Southern for re-cycling !
Peter Sarf
Croydon
O L Leigh
I think the traction motor you refer to is the EE507 (Englich Electric) which was still in (under) every EMU on the Southern until some time after after the 455s. I know the 442s used the recovered traction equipment out of the 4-REPs which I suppose was quite likely to be EE507s. So I expect the 442s are the newest EMUs that could have the oldest traction motors !. Then again given that things like traction motors get swapped around there is a chance that none of the earliest EE507s are still in use as it would be likely that the last built (suppose for 4-VEPs) would end up surviving longest even if their original home has long been scrapped.
ChrisCooper
7 Sep 2005
Loughborough
The REPs were built in the mid 60s, with another batch in the mid 70s, so the motors were fairly new, hence why they were re-used for the 442s. EE546s were also used on the 310 and 312 although heavily downrated. 455s and 456s used EE507s from later built SUBs, early SUBs having EE339s. The SUBs were the first to get EE507s. Some of the early wooden bodies SUBs were rebuilt with metal bodies and fitted with EE507s, so those pre-war 4 SUBs have lasted well and only had the motors changed once and the bodies changed twice (along with the underframe the second time).
As well as re-using servicable parts (afterall there is little to go wrong with electric motors, look at the Isle of Wight stock still going well after nearly 75 years), it also had the advantage that performance and power consumption remained pretty constant. A 455 draws the same power as any other SR 4 car EMU, a 456 the same as any SR 2 car EMU, and both perform the same as any SR 75mph EMU. A pair of 442s draw only a little more power (due to aircon) than a REP and perform similar to a REP+TC+TC set.
Another difference, 442s also reused the control equipment from the REPs, wheras 455s and 456s had new control equipment (although the 455s still use traditional resisance control wheras the 456 uses Thyristors). By the time the 442s were built, they too could have had Thyristors.
Peter Mugridge
8 Apr 2010
Epsom
Is it the early batch of 455s that were fitted with jumper cables recovered from class 76 locomotives?
matchmaker
8 Mar 2009
Central Scotland
Reliable old lumps under them - although badged "BUT" I think they were based on the Leyland O680 bus engine or a similar AEC one.
fgwrich
15 Apr 2009
Between Edinburgh and Exeter
Close - BUT - British United Traction, the former joint venture between AEC & Leyland, and as time grew on, Leyland took over AEC - Thus rebadging it simply as The Leyland 680! As for the engine itself - it use was rather widespread - anything from widespread bus use (Leyland Olympians, Bristol RE's, Leyland National 2s etc) to the early 1st generation units - Met Cams, Pressed Steels, Gloucester Units /GR&CW, BR&CW, Derby Lightweights, Cravens & BR Swindon / Derby - 108s etc, And Various types of Leyland & AEC lorrys too!
Some seem to have even found other uses too - Diggers & Heavy Plant, Marine Use (Even various fairground rides are powerd by either Leyland or Gardener LX / LW / XLB & Even earlier engines powering them {Including former pre/post war Gardener Half Cab Buses!}!) - Bloody reliable engines, just when they've been maintained properly, ive certainly got a few horror storys about 680s!
How do i know some of this, because this afternoon i was busy putting 6 refurbished pistons one of the dam 680s - still covered in oil! :roll: :lol:
Sorry, Slightly off topic! Though having said that, Chiltern & ATW??? Do still use 680 Powered 121s!
142
17 Oct 2009
the 680 was never in production olympians! It is very similar to the L/TL11 though
4SRKT
9 Jan 2009
The NIR 450 class DEMUs contain the EE 4SRKT power units, generators and traction motors from the UTA 70 class units built in 1966. I doubt anything remaining in daily service is older (or more characterful) than this.
The few remaining NIR 80 class DEMUs also have 4SRKT engines, but were built between 1974 and 1977. They do however have BR mk II bodyshells, rather than the mk III class 455 derivative of the 450 class.
ChrisCooper
7 Sep 2005
Loughborough
The TL11 is really just a Turbocharged 680. As well as the Olympians (along with Gardeners and later Cummins) they were also used in the Tiger, some National 2s, the Lynx and Leyland Lorries. They were also used originally in the Pacers, but later replaced with Cummins engines.
680s were also used in Leopards, Atlanteans and as an option on Fleetlines after Leyland bought out Daimler.
K9-70
10 Oct 2010
Belfast, N.Ireland
The power equipment (4SRKT 550hp) fitted to the NIR 450 Class Demu's was salvaged from the former 70 Class units, except for 8457 whose power equipment (4SRKT 560hp) was salvaged from NIR 80 Class No.88 which was written off after being involved a fatal accident at Hilden 25-03-1983
http://www.railphotoarchive.org/search_engine_2.php?_format=4&img=0681021557000&_PAGE=1
K9-70
K9-70
4SRKT
9 Jan 2009
Eng274
19 Aug 2010
Straying from the EMU/DMU path here, but do the class 08 shunters not have the oldest engines in operation? They may or may not be technically mainline stock, does this disqualify it?
LE Greys
6 Mar 2010
Hitchin
How much mileage would a shunter clock up? In terms of hours, the 6KT engines must be pretty high, but I reckon that the 8SVTs in the 20s have probably covered far more miles, especially considering that their previous main duty was the near-constant movement of an MGR, then the long-range diagrams from Sellafield to various other power stations as far away as Dungeness. Otherwise, my guess would be whichever VP185 has been in use for longest, since they were installed on the very-high-mileage HSTs, and have been around for longer than the MTUs, although they are catching up, because of the longer EC diagrams.
BestWestern
6 Feb 2011
Hi all, just to pick up on an earlier post, DMU engines are indeed swapped over at a certain mileage and replaced with reconditioned units; there's no way one engine could ever last the life of the train. A fitter did quote the recon mileage once, but alas I can't remember what it was :| If you consider that most units are fired up in the early hours, run all day and then only get put to bed late at night, that gives you an idea of the wear and tear levels. Plus the long periods of idling apparently do a diesel lump no good as the fuel doesn't burn properly and sits in the cylinders ( I'm reliably informed!) which doesn't help matters. I seem to recall a mass re-engine program on the 158s a while back due to the original (Perkins?) units being hopeless, anyone else have a better memory?!!:oops::oops:
Peter Sarf
Croydon
Oh, youre so wrong, it does indeed HELP matters. How else does one expect to get such wonderfull CLAG when accelerating away :lol:.
BestWestern
6 Feb 2011
Excellent lol! :D FGW's are more prone to clattering engines but with only modest amounts of clag. Our best polluters seem to be the 143s!
tempests1
3 Aug 2010
Haslemere
It also depends on whether you count the reused traction on the 442s as making them earlier <D
Didn't they recycle the Traction Motors from the 4REP's for the Wessex Units?
In a similar vain the SWT/Southern Class 455's carry all the traction equipment - 4 x 250hp Traction Motors from 4SUB Units. The last of those trains were built late forties/early fifties. The Southern Region were very good at re-using things.
