backontrack
may I ask if this is a serious suggestion?
Yes, it is. It also releases capacity.
But crucially, it's less likely to be blocked by Virgin.
TBH, I didn't know it was single.
Its been single track since the through line to Blackpool central was closed along with that station.
I think some of the track bed exists. In some ways its a shame its not connecting to Blackpool north, but that would essentially replicate the tram, albiet with a less scenic view.
There's been talk of that turning it in to an extension of the Blackpool Tramway for years too.
I don't think Blackpool Airport will be a big draw... it closed down last year!
It wouldn't have blocked the lines for too long (he says...) as it would dump people out and go into the up and down loop. If Alliance wanted to stump up the cash to do something to Primrose Hill I've no doubt it could be looked at.
In the meantime, Network Rail and Grand Central have agreed a plan to terminate services at Queens Park (London). Trains will then run ECS into the Kilburn Up and Down Goods Loop immediately east of the station. Turn-round time in the loop is expected to be between 15 and 40 minutes depending on the outcome of detailed timetable development work. This method of operation has been validated by Network Rails LNW Route Team. The only scheduled use of the loop in the current timetable is one train on a Saturday morning.
Northbound services will depart from the Down platform and cross to the Down Fast at the earliest opportunity.
Just for emphasis, this was actually explained in the track access details posted earlier in the thread:
If that's all correct then Primrose Hill seems a bit of an irrelevance.
It's not the reversing or holding in a loop more the tip out and boarding times at the Park. This is a long distance service with fewer doors, people with luggage etc having it sit on any of the through roads at the Park for more than 5 minutes might cause some blocking back.
How would onward connections from Primrose Hill work though?
It may need to be re-opened anyway if Euston is to be demolished for HS2.
Euston isn't going to be demolished, just extended a bit.
Surely it would make more sense to use bi-mode units, DMUs or locos and run into Blackpool South? There's more demand in Lytham, St Annes, Ansdell etc. that is untapped. This would also connect with Blackpool Pleasure Beach and Blackpool Airport (the latter at Squires Gate).
Now re-opened.A bit late to offer services to Blackpool Airport as it closed to commercial flights last year.
Now re-opened.
Really? So what planes other than private jets and light aircraft actually use it then? Where can you fly to/from?
The Isle of Man.
The Isle of Man.
