Essentially, the differences between the Pacer classes is as follows:
Class 141 BREL underframe, shortened Leyland National body built to standard road vehicle width. 2+2 bus seating, one set of passenger doors on each side of each vehicle, separate cab door for traincrew use only. Delivered to Neville Hill for use on Leeds - Harrogate - York, Leeds - Knaresborough via Harrogate but also Leeds - Doncaster, Leeds - Huddersfield and York - Sheffield. First two units delivered in a variant of BR Blue and Grey incorporating yellow passenger doors and Barrow Corporation blue paint rather than Rail Blue, remainder of fleet delivered in West Yorkshire PTE Verona Green and Cream bus livery. Fleet rebuilt in 1988 by Hunslet-Barclay to incorporate modernised braking system and updated couplings to make them compatible with the later Pacer classes. Highly unreliable, all withdrawn by 1998. Three preserved, including the unique 141113 (modified with a Cummins engine and Voith transmission in 1987), remainder largely scrapped.
Class 142 Essentially a revised Class 141 - incorporating a longer and wider Leyland National body. 3 sets of passenger doors on DMSL vehicles, 4 on DMS ones. Loss of separate train crew door means crew access is now via the first set of passenger doors on each side behind the cabs. Internally - 3+2 seating fitted to all units at build however majority now fitted with individual 2+2 high back seating in various styles with a few still retaining their original fixed bench seats. Driving cab revised, losing the raised Leyland National style driving position and Leyland National dashboard as fitted on Class 141, in favour of a completely conventional railway style dashboard. Delivered in three liveries; Greater Manchester PTE orange and brown, mock-GWR Chocolate and Cream (for a highly unsuccessful life on the Western Region in Devon and Cornwall), and standard BR Provincial two-tone blue and white livery. Entire fleet modified in the 1990s to incorporate a Cummins engine/Voith transmission to replace the original Leyland TL11 engine and Self-Changing Gears transmission, external doors modernised to incorporate the same rigid inward pivoting type used on Classes 143 and 144. Class largely still intact as of 2017, with two scrapped from accident damage - 142059 in 1991 after running away and hitting buffer stops at Liverpool Lime Street after loss of brakes, 142008 after colliding with a Class 87 hauled West Coast Main Line express at Winsford in 1999.
Class 143 The only Pacer class not built in any way by BR - these incorporated a body supplied by Walter Alexander Coachbuilders of Falkirk, Scotland, mounted on underframes built by Hunslet-Barclay at Leeds. 3+2 seating fitted inside originally, since around 2000 fleet has run with 2+2 high back seating. Leyland TL11 engine and Self Changing Gears transmission fitted at build in 1985/6. Updated door system fitted from new - rigid inward pivoting doors fitted instead of the collapsible four section Deans type fitted on Classes 141 and 142. Originally delivered to Heaton depot in Newcastle for use on Saltburn - Bishop Auckland via Darlington and local services around Tyneside, Teesside and Wearside. Majority of fleet delivered in Provincial Services two-tone blue and white as per later class 142s, though final units of build delivered in Tyne/Wear PTE yellow/white bus livery of the time. Transferred away to the South West and Wales in the 1990s. Entire fleet modernised with a Cummins engine and Voith transmission shortly before transfer from the North East. Two sets, 143613 and 143615 withdrawn due to electrical fires and scrapped in 2005, remainder still in service.
Class 144 Variant of Class 143 featuring the same Alexander body but on the BREL Derby chassis used on Class 142. 3+2 seating fitted, trimmed in identical orange/brown/beige moquette as used on Class 143. Leyland TL11 engine and Self Changing Gears transmission fitted at build in 1986/7. Final 10 units of build extended in 1988 to run in three car form, with a distinctive centre coach with four doorways at each corner fitted between the two driving vehicles. Class delivered exclusively for West Yorkshire PTE and painted in the crimson/cream MetroTrain livery of the time. Introduced to supplement Class 141 on WYPTE local services. Fleet modernised with a Cummins engine and Voith transmission in the 1990s. Withdrawal of Class 141 sees this class almost completely take over all services formerly operated by Class 141, with the fleet becoming largely the standard type of rolling stock on Leeds - Harrogate - York services until 2007. Fleet modernised again between 2002 and 2004, receiving high-back airline style seating. Fleet painted in a third and final version of WYPTE livery, before being repainted in standard Northern Rail livery from 2008 onwards.Entire fleet still in service as of 2017.
