Passed train driver assessment :)))
danbox1981
21 Jan 2017
Hey guys and gals , I've got my first assessment day this week for southern at East Croydon could someone please verify that on day 1 it is just group bourdon, Tea-occ test , trp test and also the sheet for the mmi ??
Sent from my SM-G930F using Tapatalk
choochoochoo
6 Aug 2013
No, you also do 2Hand, Reaction, Vigilance, SJT assessments
The only things left after first assessment are DMI and MMI (and then medical)
danbox1981
21 Jan 2017
there was another attachment in the email with driver fault finding test (DFFT) material, when would that be tested?
Need2
15 Jun 2016
The same day.
All the tests are run on the same day, if you or anyone else fails any part of any test then you are called out and sent home.
As said before it's then the DMI, MMI (should you be successful) then the medical on other separate days.
Good luck!
danbox1981
21 Jan 2017
The same day.
Good luck!
Thanks for the info ☺️
Ian888
24 May 2017
Hi folks I have my assessment coming up next week and just wanted to know how many people were at the assesment?
king_walnut
16 Oct 2013
At my assessment, 12 people started .. 6 fell at the first stage which was Group Bourdon .. and just me and one other finished.
Sotac464
15 Feb 2017
Thanks I printed off GB 5 sheets. Managed 8-9 lines on each correctly in 2mins.
Scaat printing off next.
Shouldn't need to practice Scaat. If you do gbt then you shouldn't need to do the other. Obviously depends on different tocs but I didn't need to practice Scaat.
Garyhobbs
10 Mar 2017
Ok, does anyone know if GTR does a test on the Scaat paper? I don't see it in my practise papers so I guess you are right.
Cheers
GMT
29 Aug 2015
Kent
Cheers
Dots, they do DOTS. I did dots with them last year. Five pages.
Good luck.
tracerboy
15 Feb 2017
Yep will be a dots test, just print off 5 sheets each day on the lead up and practise everyday and you will find it a lot easier, its about training our brain for them.
Have my medical this afternoon then should be all good to go hopefully.
king_walnut
16 Oct 2013
Hi, I have an assessment on the 29th June..But I didn't receive any paper work to study, did you?
The practice material is in a PDF attachment to the email you get confirming your assessment date. If you didn't get it then contact them.
Demonbarber
27 Jun 2017
Hi, I passed the assessment stage one last week and was wondering if anyone could tell me how long you had to wait to hear from them to book stage two of assessments? They said to me they would be in contact about the next assessment and haven't heard anything since.
Thanks
Cheryl
27 Feb 2018
Hello!
I’m not even sure if this thread is still open. I have my train driver assessment coming up and I was wondering when doing the tones and phone directory assessment, how quick did the tones come? I’ve heard a few on YouTube and they are really fast beeps. Is that the way it is On the day?
Any help is appreciated as with Any tips for the assessment !!
andys495
20 Oct 2016
I recall about one every second (approx). Focus is the key. Some people count the relevant tones off on their fingers. Like a lot of the other tests this one is designed to see if you can divide your attention and it’s not really something you can train for. You can either do it or not. Good luck!
Cheryl
27 Feb 2018
Thank you for the advice!! I’m really nervous! How long do you have to count the tones and search the directory eg is it like 2 minutes per page etc?
andys495
20 Oct 2016
I did mine over a year ago so I’m going from memory, it’s not that long. Maybe 30 seconds or so, which doesn’t sound long but if it’s a tone a second that’s plenty of time to test the grey matter. Try not to be nervous cause that won’t help. Remember it’s not impossible or there wouldn’t be any drivers.
andys495
20 Oct 2016
Remember to listen very careful to the instructions of the test and be certain what is required. If you’re not certain keep asking until you’re happy what to do. That’s within the rules. Friend of mine failed that test because he didn’t listen properly. The directory is normally a list of tradesmen. I think I had plumbers and they ask you to pick out certain ones. But they all have different symbols next to them eg two crosses or two circles etc. What they will ask you to do is pick out all the plumbers with two circles next to them for example. They not expecting you to physically read every one. My friend did this and took too long. Also most of the tests are timed. You won’t complete the tests before your time runs out. They’re designed like that to put you under pressure. Work quickly but accurately.
Cheryl
27 Feb 2018
Thanks for the update Andys495! I will definitely make sure I understand the objective before starting!
Do you know what the pass rate is? Or how I can work out the pass rate?
Also, the assessment with the passage and then the questions. How’s best to prepare for this? How long roughly is the passage? And is the passage always on something train related? I have never been front line and so my operational knowledge is limited, would this go against me for this assessment?
andys495
20 Oct 2016
Nobody at ground level knows the pass mark. It’s one of those railway mysteries. Even to this day I don’t know how close etc I got to the pass mark.
The reading exercise is roughly two sides of A4. It will have a railway theme but will not be factually correct. For example my text talked about the laying of glop on the rails to help traction. There’s no such thing, it’s called sandite.
Try and remember numbers, colours, order of process etc. You’ll have time to read it and take notes but both the text and notes are collected in and a few minutes pass before you’re asked to recall the passage with multiple choice questions. I thought I hadn’t done that well on that one but obviously was ok.
To practice the only way I can think of is to get somebody to read you a passage of technical text maybe and see what you can recall.
1 Mar 2018
Hello!
I did mine last week and they were quite quick (they seemed less than a second, but I was quite nervous so who knows!) but they are all the same frequency which made it a bit easier (for me) than the test which had two different tones.
Andys495 is spot on about the Glop passage and I would reiterate the advice they give about taking notes - it really helps with committing information to memory
Good luck!
Cheryl
27 Feb 2018
Good luck!
Thank you!! Good luck on your results! The only part of the assessment I am worried about is the tones because there is not much out there that you can use to prepare for the tones!!
Hopefully it all goes well!
1 Mar 2018
I'm sure you will be fine - we had the tones at the very beginning of the assessment and there was a lot of adrenaline flowing which didn't help!
You can get musical keyboard apps for smartphones, so I suppose you could download it and get a friend to tap away whilst you counted. As I said, I found the 2 tone test more difficult than the tone/directory test but I didn't practice for either!
Cheryl
27 Feb 2018
Hello! Passed stage one!! Hurrrayyyy! And now onto stage 2- the computer tests. I have a few questions that I am hoping you can all help with
1) 2 hand co-ordination test: how sensitive is the controls? I’ve heard of the screen freezing etc, does this actually happen? Also I know you have to do the same shape 10 times but I assume this is timed? If so, how long do you have? What’s the best way to practice ? I’ve just bought the metal wire game, did you find that it actually helped?
2) the WAFV Vigilance Test: I don’t even know where to start with this one! How on earth do you prepare for the change in colour?
3) interview: I am assuming this is competency based or is there technical questions thrown in? Who normally takes this interview? DTM’s? HR?
4) written communications test: is this similar to the practice materials (in the form of a comic strip?) and when your writing the report, are the pictures taken away and you need to remember the key facts?
Any help is as always so appreciated!!
