DarloRich
Doesn't happen much anymore. Was more common when IC sets went to Harwich. These days anything needing turning is done at High Meads, Manningtree or Norwich.
Of course. Thanks.
For me, worrying about the formation is the most stressful part of any journey I make (as described in a trip report from last year). Given that they manage only 17 stations, sending the needed info to each station should not be rocket science...
How about painting a mark on the front of the train at the first class end, as was done by BR on some units. At least then the regulars would get a couple of hundred yards warning to start heading up or down the platform.
where can you turn a set on the GE?
I'm pretty sure you could as well.Without looking at a map I'm pretty sure that it could be done at Crown Point?
I have been sworn at by a Virgin guard while running from one end of Warrington BQ to the other to get on a Full & Standing train - I replied that I was only trying to board my coach where their own system had told me to stand, if it was at the other end of the train that was hardly my fault!
The EMT class 222's (Meridians) have the bar on the auto-coupler painted yellow at the first class end and plain at the other end.
I personally cant really see any problems with this 390 being the wrong way round. I dont think it will really inconvinience any passengers. Im sure the majority of passengers wont know where 1st class or std class is before boarding the train anyway.
I imagine this does probably happen a lot. A few days ago i came across a 442 which was the wrong way round. Normally the 1st class should be in the south end of the middle (3rd) coach but this time it was in the north end of the middle (3rd) coach instead.
They can be 11 coaches long!
I'm not sure how many people would know but for as long as I've been using the railways first class has always been at the "London end" of any train.
Onilodnep.
That is all.
My rail atlas indicates there is a single line north from Oxley to Bushbury Junction where they can , if needed turn the Pendelino again so its correct way round for the tdays services south from Wolverhampton .
Anytime I travel from my local station which is Martins Heron on the Reading - London Waterloo, it always mentions as part of the PA announcements the length of the train whether it is 4, 5 or 8 cars.
If South West Trains can have their PA systems be able to tell passengers prior to the arrival of the train as to how many coaches the train has, then as stated previously in this thread why cannot this be done with the VWC PA system?
Unfortunately the Oxley chord isn't wired, so it wouldn't be any good for turning Pendolinos, though I guess they could use it for Voyagers (assuming crews signed the route). Instead, when a unit has needed turning, I have seen Virgin run a Wolverhampton-Wolverhampton ECS move via Galton Jn-Soho N-E-Perry Barr W-N-Bescot-Portobello.
Suppose a passenger was travelling with a bicycle? That passenger is now 1/4 Km away from where they need to be. Assuming a walking speed of 1.4 m/s (3 mph) that's nearly two minutes to get to the other end of the train.
So a Pendo unexpectedly arriving in reverse would be delayed by two minutes. If it happens at two stations, that's four minutes delay for every passenger on the train...
Yes it will. Possibly not on that line but I've certainly heard those announcements WRT first class on trains on other SWT routes, and on FGW routes.There is a difference. SWT run trains in fixed formations. 2, 3, 4, 5, 6, 8, 9, 10, 12 cars based on unit type and diagram. The CIS is programmed for the expected diagrams which have a set number of units of specific type. It won't tell you if the unit or units are the wrong way round which affects where First Class is.
There is no doubt that trains are delayed by the operating companies not updating passengers on the platforms.So the poor sods waiting at the end for coach A (quite zone) find themselves climbing on to be greeted by the kitchen and big blue seats with hankies on the back. Do you risk getting off or walk through all 11 coaches while people are stowing their luggage and faffing about/sitting by the bogs in the doorways etc?
