70014IronDuke
- Joined
- 13 Jun 2015
- Messages
- 3,699
I've extracted this from this thread
https://www.railforums.co.uk/threads/br-type-3s-regional-preferences.161534/
on BRCW Type 3s ( Class 33) as it was veering way off topic.
To be fair, WCML expresses in the early 60s were HEAVY - I mean, 14-15 carriages were normal - and were not timed for anything much faster than 75 max, I should think. Does anyone have logs of Cl 40s on the ECML of the time, I wonder - I suspect with 10-11 carriages, which was more like the average load out of KX by then, you would get higher speeds out of a 40.
This is so far off topic - I'm gonna start a new thread.
This subject of "lumbering" Class 40s (my quotation) has come up before - and Bevan has also come down on Cl 40s before I think. It's obvious that these engines were overweight, but I kind of feel they weren't quite as bad as Bevan and some others make out.
Has anyone got logs of Cl 40s on faster timings and lighter loads than was usual on the WCML in the early 60s. (The timings out of Euston in those years were usually quite slack to allow for electrification work.)
A run on the GN would probably serve to prove the point either way. I suspect a 40 with ten on could get into mid-80s between York and Darlington, for example - but only a log would prove that.
Class 37s were also not famed for fast running, at least when working singly, but then their main duties was freight, except for some years on the GE Kings Lynn line. I think they did work The Master Cutler and the Cleethorpes - KX express c 1963, but then lost that run to Cl 47s. (I know they famously worked some Scottish lines pre sprinterisation, but those lines are hardly the place for speeds above 70 mph.)
On the heavy loads on WCML passenger services in the 1960s, you would be lucky to get much faster than the high 70s (mph) unless you were going downhill - and 25 mph up Shap was typical. A good condition Pacific with a willing crew could outrun a 40. However, in later years of the steam era, getting a good quality Pacific (& willing crew) was unusual, and the 40s were more consistent....
