johnnychips
Not surprised!With a railcard, I have never encountered a situation where flying has worked out cheaper than flying.
When I went to school on an RT in the 1960s someone told me (an engineer making the same journey, maybe) that a diesel [bus] engine would consume 1/2 pint of fuel per brake-horsepower per hour! It could have been true then, maybe things have improved since, but it's a good point that any improvement will have been swallowed up by things like a/c, heavier (safer) build, the added weight of double glazing, maybe even automatic gearboxes...well if the bus industry is anything to go by er.... no... due to all the legislation on emissions and extra weight due to more stringent safety requirements a modern DD returns 4-5 mpg compared to a typical late 50's/ early 60's figure of between 8-10 mpg
So it’s a successful refurbishment.Here's a misconception I've heard several times recently: That the refurbished 185s are new trains.
That generally its cheaper to fly domestically rather than take the train. Utter nonsense usually based on comparing Ryanair prices with those of a full price return which isn't exactly fair...
I agree that the quotes which try to make rail travel sound as expensive as possible are highly misleading. I have seen them compare peak time first class rail tickets to a standard economy class flight, well of course the train is going to be more expensive if you cherry pick ticket types to support an agenda, but it is not compulsary to travel first class or at peak times, it is possible to get very reasonably priced long distance rail tickets with a bit of research, effort and flexibility.
One myth not yet mentioned is that, on a 12 coach train at a London Terminus, all the seats are in the rearmost carriage. This is often linked to the myth that the red signal blazing down the platform is just for decoration and that, even though it is 17:32 for a 17:35 departure, the train is about to leave.
Comparing X to London, rail and air do tend to be reasonably competitive, provided that X is a regional centre that has an airport and a convenient connection for London.London to Inverness flying compares favourably with the train just including the station to station and airport to airport journey, but there is the additional cost of getting from home to the station/airport then getting to your destination at the other end.
Have you tried Skyscanner? There you can get all flights, include any combination of London airports, and filter by departure and arrival times. I don't know if it will always find the cheapest (and price sometimes varies slightly when you're transferred to the actual booking website) but it's always my first point of call for any flight. You can also deselect any airlines, so I can make sure Ryanair doesn't appear (since I aim never to fly on it again).I've found that getting a cheap flight is at least as much effort, if not more effort, than getting a cheap train fare, especially because finding the best deal on the Edinburgh to London route involves having to check at least three airlines, if not more, whereas all train fares can be viewed in the same place.
A few years ago I worked out fuel consumption vs engine power for construction plant based on values from the Caterpillar handbook, and it was a surprisingly linear graph and very similar across most categories of plant. Average value was about 1lit per 6bhp-hours, so about 0.3pints per bhp-hour. So it looks as though efficiency has improved since the 1960s, but it's not that far from your figure.When I went to school on an RT in the 1960s someone told me (an engineer making the same journey, maybe) that a diesel [bus] engine would consume 1/2 pint of fuel per brake-horsepower per hour! It could have been true then, maybe things have improved since, but it's a good point that any improvement will have been swallowed up by things like a/c, heavier (safer) build, the added weight of double glazing, maybe even automatic gearboxes...
If travelling from X to Y, where both X and Y are regional centres, it tends to be pretty clear cut. It's either too short a distance for the airlines to be interested in, so rail is the only option (despite often taking longer than getting to London), or else it's a long distance route where there's a direct flight but the railway expects you to travel via London. I encounter this often enough for it to be really annoying: Scotland to south-west England is totally impractical by rail since the journey takes an entire day.
I have heard before on here that passengers have a tendency to head for the first available door and cram into the rear carriages whilst the front ones are empty.
Let's take a real world example, from my local airport (Aberdeen) to London (assuming everything runs to time and my arrival on the platform coincides with the arrival of the necessary trains/Underground, etc).Also London to Inverness's rail journey time of 8 hours does not compare well with flying at all, even when factoring in transfers and security. It's attractive to to those who genuinely prefer the train over flying, the environmentally conscious and occasions when the train is cheaper.
The train competes well for London to Edinburgh / Glasgow routes as the additional 30 - 60 minutes travel time is a worthy trade-off for a seamless travel experience. As for London to almost any English or Welsh city, flying is a minority sport as it takes longer.
I maintain that, in terms of time there's nothing in it, but in terms of the entire cost for the full journey (especially if you book in advance), factoring in money, comfort and best use of time... the train wins.
The class 91 traction package was pretty much an APT power car though.That Class 91 + Mark 4s were derived from the APT.
Thank you for proving my point!The class 91 traction package was pretty much an APT power car though.
Flying:
My house to airport: 1 hour drive
Get there well in time to negotiate queueing for baggage dropoff, queueing for security, etc: 1.5hrs
Time between boarding and departure: 30 min
Flight time: 1hr 10 min.
Wait for baggage at reclaim: 15-30 min.
Exit airport and head for station: 15-20 min
Train to London: 30 min (if train arrives at platform at the same time as me)
Underground to nearest station to my destination: 20-30 min.
Walk to my destination: 10 min
Total time: 6hrs, give or take 10 minutes
Train:
My house to nearest station: 20 minute drive
Train to King's Cross: 5.5hrs
Walk to destination: 10 min
Total time: 6hrs.
So... time-wise there's nothing in it. However, let's factor in that much of the train journey is time in which I can sit and work, whereas a lot of the time on the air journey is standing around getting hot and bothered in queues, dicking around with security or running around airports and for trains.
In addition, I'm saving up to £60 on airport parking and there's no fare to get from the airport into London.
Then you factor in that the headline prices of 'cheap' flights on the likes of Skyscanner look really cheap... except once you book you have to pay extra to choose your seat, have hold baggage and all the rest of it.
Please provide evidence that this website is "full" of people describing anyone who hints at liking IEPs as an "anti-patriotic Nazi".That the HST is the greatest train ever and should be kept in service forever and anybody who even shows a hint of liking the IEP is an anti-patriotic Nazi. (This website is full of this)
The Nazi bit was an hyperbole. I was basically saying that generally people don't like trains from aboard and are very 'close' to the HSTs.Please provide evidence that this website is "full" of people describing anyone who hints at liking IEPs as an "anti-patriotic Nazi".
Bet you can't.
Sainsbury’s use the vacuum pipes for bundles of notes and definitely do it during the day.
Might possibly be only the till supervisors that use them though
Leaves on the line is a made up excuse.
Rail staff actively go out of their way at every opportunity to irritate passengers.
There are extra coaches lying about everywhere that we refuse to use in service.
That there is a prize at Euston for the first person though the gatelineI have heard before on here that passengers have a tendency to head for the first available door and cram into the rear carriages whilst the front ones are empty. I even used that information to always board the train further along the platform at peak time to board a carriage that isn't rammed full. I have to say that when I have boarded a train at Victoria heading for Horsham, passengers do tend to use the full length of the train to board, so boarding further down doesn't really give much of an advantage, other than I walk faster than most people.
