'Pick up only' on selected weekdays - Milton Keynes - Virgin Trains (West Coast)
All Line Rover
17 Feb 2011
I mentioned a few weeks ago that, from the May 2016 timetable change, the 19:10 London Euston to Holyhead train will be calling additionally at Nuneaton and Stafford. The train is already overcrowded with its current calling pattern of Milton Keynes, then Crewe, then Chester, and stations to Holyhead.
Virgin can't remove Milton Keynes as a calling point because doing so would break the hourly service between Milton Keynes and Crewe/Chester (with connections at Crewe to Liverpool, Warrington and stations to Scotland, Shrewsbury, and Manchester Airport). On the other hand, allowing Euston to Milton Keynes passengers on this service will result in passengers travelling beyond Milton Keynes being unable to board the train at Euston (and for stations beyond Chester, the 19:10 is the final direct train of the day!).
Rather than reverse the idiotic decision to add Nuneaton and Stafford as calling points (in place of these stations as calling points on the 19:07 to Liverpool), in the last few days Virgin has made Milton Keynes 'pick up only' on the 19:10 (from May) on Thursdays and Fridays only. And that's not all, because Virgin has done the same with the 19:20 to Manchester (which is having Macclesfield added as a calling point, replacing Macclesfield as a calling point on the 19:00, with the journey time to Manchester on the 19:00 reduced by a mere five minutes, from 2h 13m to 2h 08m), resulting in a one hour gap in Virgin Trains services to Milton Keynes on Thursday and Friday evenings (between 18:43 and 19:43)!
Two concerns I have about these planned changes are:
1. How is a 'pick up only' restriction on selected weekdays going to be enforced? If the 19:10 and 19:20 can be used by Euston to Milton Keynes passengers on a Wednesday, why would they not use either on a Thursday? Many obnoxious* Milton Keynes commuters can't even comply with the 'pick up only' restriction that applies, every weekday, to the 17:10, 17:20, 17:43, 18:10 and 18:20 Virgin Trains departures from Euston, even though, for the 17:10, 17:43 and 18:10, there is a two minute (2 minute!) slower London Midland service just behind. [*Most Milton Keynes passengers are well behaved, but I don't have a high opinion of those who feel they are entitled to use a £15 Anytime ticket to travel on a train, such as the 17:20 or 18:20, where every passenger leaving Euston who is holding a valid Anytime ticket has paid, at a minimum, £140 for a ticket to Stoke-on-Trent.]
2. As the 19:10 and 19:20 are both likely to be full and standing leaving Euston because of the new calling points (Nuneaton and Stafford, and Macclesfield), and as no (legitimate) passengers will be alighting at Milton Keynes, how are passengers boarding at Milton Keynes supposed to get a seat (which is particularly essential on the 19:20 considering they will otherwise be standing for one hour to Stoke-on-Trent)? At least the present timetable allows passengers boarding at Milton Keynes to displace passengers alighting at Milton Keynes, and because Nuneaton and Stafford, and Macclesfield, respectively, are not calling points, the 19:10 and 19:20 aren't so overcrowded as to leave long distance passengers behind at Euston.
DarloRich
Fenny Stratford
wow - Can virgin ever do anything right as far as you are concerned. Sorry us pesky MK commuters paying our 5k per annum season ticket prices get in the way of your travel enjoyment. That must be awful for you.
And quite obviously the restriction aren't going to work, especially when the automated barriers are in use.
All Line Rover
17 Feb 2011
Had you bothered to read the post, you would realise that Milton Keynes passengers won't benefit from any of the planned changes.
DarloRich
Fenny Stratford
we never do!
The emphasis is on placating longer distance passengers (paying less often) versus a large number (and guaranteed income stream) of shorter distance commuters. Which is the right answer?
If I have been at work at 0730 in London meaning leaving the house around 06:00 I want to be home soonest. That is 5 days a week, not once in a while like the longer distance passengers.
AND i have to pay c.5K for a season ticket in one go
we never do!
The right answer, as just about every other European country knows, is that long-distance trains are for long-distance passengers, and local trains are for local passengers. If you do otherwise you end up shifting a lot of fresh air once the commuters have got off.
MK passengers do benefit from VTs, of course, and it's up to VT if they happen to want that extra traffic. But the VT service should never be planned around MKC commuters.
(Similarly, and for balance, you know well what I think about an absurd pricing policy cramming long-distance passengers onto overcrowded 1tph 4-car LM services while VTs flash past with plenty of space)
DarloRich
Fenny Stratford
The timetable/ticketing doesn't work and needs sorting out. Either Virgin give up all peak hours provision to MK (say 06:00-09:00 & 16:00-19:00) AND the revenue that goes with that or they and LM sort something more sensible out.
I doubt LM could carry all the passengers between the two stations (and still provide for those commuters from further north and south - the bubble is expanding to Rugby now) and I doubt Virgin want to give up the revenue.
The LM trains out of Euston are very busy (and that ISN'T cheap fares in the peak) with regular standing beyond MK. So to my mind you either stop more Virgin trains & dump the peak hours restrictions or you stop none. I say run a pendo extra Euston - MK/Northampton in the peaks ;)
PS we wont agree on the pricing structure so I suggest we park that in the car park for now!
All Line Rover
17 Feb 2011
The emphasis is on placating longer distance passengers...
Long distance passengers won't benefit, either.
This is the existing calling pattern:
EUS 18:57 > CRE 20:33 > SPT 21:01 > MAN 21:10 (2h 13m - relief service)
EUS 19:00 > SOT 20:24 > MAC 20:41 > SPT 20:55 > MAN 21:11 (2h 11m)
EUS 19:07 > NUN 20:02 > STA 20:26 > RUN 21:00 > LIV 21:21 (2h 14m)
EUS 19:10 > MKC 19:40 > CRE 20:47 > CTR 21:13 ... HHD 22:56 (3h 46m)
EUS 19:20 > MKC 19:50 > SOT 20:48 > SPT 21:16 > MAN 21:28 (2h 08m)
And this is the calling pattern from May:
EUS 18:57 > CRE 20:33 > MAN 21:10 (2h 13m - relief service)
EUS 19:00 > SOT 20:24 > SPT 20:52 > MAN 21:08 (2h 08m)
EUS 19:07 > RUN 20:50 > LIV 21:08 (2h 01m)
EUS 19:10 > MKC 19:41 > NUN 20:11 > STA 20:36 > CRE 20:53 > CTR 21:10 ... HHD 23:03 (3h 53m)
EUS 19:20 > MKC 19:51 > SOT 20:49 > MAC 21:06 > SPT 21:19 > MAN 21:31 (2h 11m)
(The changes to the 18:57 relief service are interesting. It no longer calls at Stockport, and gets overtaken on arrival into Manchester by the 19:00.)
I also believe that Milton Keynes passengers boarding the 19:10 or 19:20 at Milton Keynes count as 'long distance' passengers. They will be big losers.
TBH I'd say send the 350/4s to LM once TPE are done with them, and a chunk more 319s (sufficient sets to operate the entire Tring stopping service, say), and have absolutely everything out of Euston between 1600-1930 and into Euston between 0630 and 1030 including shoulder-peak running as 12-car, and a complete end to 4-car operation throughout the LM WCML operation south of Northampton at all times.
I don't to be honest think the present situation is all that bad. I have a very good record of a seat when I have used peak services out of Euston. You sometimes just have to be a little selective over which trains you use. Fortunately LM publish loading information so it isn't pure guesswork.
There is an argument for 125mph fasts on the next proper LM franchise - but something like the Desiro Verve may be a more logical choice.
DarloRich
Fenny Stratford
TBH I'd say send the 350/4s to LM once TPE are done with them, and a chunk more 319s (sufficient sets to operate the entire Tring stopping service, say), and have absolutely everything out of Euston between 1600-1930 and into Euston between 0630 and 1030 including shoulder-peak running as 12-car, and a complete end to 4-car operation throughout the LM WCML operation south of Northampton.
I agree. I tend to aim for the slower trains as they tend to empty out after Watford/Hemel unless i am grumpy and want to be home asap when i will cram on a fast one
6Gman
1 May 2012
I use the 1910 from time to time. Have never failed to get a seat.
All Line Rover
17 Feb 2011
It doesn't call at Nuneaton or Stafford - yet. And if you happen to board at the last minute (which I do occasionally), you can at least get a seat from Milton Keynes. That won't be possible when Milton Keynes becomes 'pick up only'.
Kite159
27 Jan 2014
West of Andover
By checking tickets and if any Milton Keynes passengers somehow manages to board and is caught will be charged the full anytime single ticket from Euston to the first 'stop', i.e. Stoke.
In the eyes of an outsider it makes sense to give priority to those travelling longer distances to the commuters who have alternative services. I.E. Pick-up only restrictions at Woking in the evening peak for those services which call there & Reading for the Friday 18:03 Penzance HST.
All Line Rover
17 Feb 2011
In the eyes of an outsider it makes sense to give priority to those travelling longer distances to the commuters who have alternative services. I.E. Pick-up only restrictions at ... Reading for the Friday 18:03 Penzance HST.
So there is at least one example of a 'pick up only' restriction on selected weekdays. Interesting. Are there any others? And how does anyone using the GWML find the 18:03 to be in practice?
DarloRich
Fenny Stratford
the guard wont get through a full train - you have to catch the tickets at the gate and turn them back.
Antman
3 May 2013
Is that what will actually happen or just what you want to happen? If they refuse to pay up can they actually be prosecuted for travelling from Euston to MK with a Euston to MK ticket?
charley_17/7
1 Sep 2006
Milton Keynes Central
London Midland care as much about lost revenue from Virgin as much as Virgin do about serving the Milton Keynes market properly. Neither could care less.
6Gman
1 May 2012
Yes.
Their ticket is not valid.
323235
8 Dec 2007
North East Cheshire
So as a result of Virgin's meddling with the timetable, Macclesfield will now have 2 trains to Manchester within 9 minutes of each other in the 2000 hour (XC & NT) then nothing until 2107 when they will run 2 x VT services in the same hour and there will be 3 trains (VT/XC & NT) in the space of 14 minutes.
Could they not just have left Macclesfield calls alone or even made it pick up only so Macclesfield passengers don't lose out
Hadders
27 Apr 2011
Isn't the infamous 1915 from Paddington pick-up only on Friday's only? Of course that's solved all the problems on that line.
Technically an Anytime Single from Euston to Stoke could be charged to someone holding a EUS-MKC ticket but the press would have an absolute field day.
A manual barrier check would be needed to stop people using MKC tickets on these trains but these are being replaced by automatic ticket barriers which I suspect ill simply accept the ticket.
All Line Rover
17 Feb 2011
Especially when almost everyone else on the train, regardless of whether they boarded at Euston or Milton Keynes, will hold an off-peak ticket.
driver_m
8 Nov 2011
Go and see the evidence of the 1900 or 1907 services when they're disgorging at Picc or Lime St. Euston is a seething mass of frustrated humanity on a Friday night. As for the other point about travelling, the TM's can and will charge to the next stopping point on those trains if you have a ticket to MK. The 1910 will likely be off 18 anyway so I'd imagine it unlikely that it doesn't get barriered by RPI's and the situation happening being unlikely.
ScouserGirl
28 Dec 2015
Is that actually true about the 1907 EUS to LIV just stopping at RUN?
That he is allowed to, and will attempt to, does not follow that a prosecution would stand up if the passenger refused.
Has one succeeded?
Antman
3 May 2013
Yes I could imagine the press loving that:D
Forgive me if this has already explained and I've missed it, but if the Milton Keynes stop isn't advertised at Euston how do these commuters know it will stop there? I wouldn't want to risk being whisked off to Stoke on Trent, perish the thought;)
cactustwirly
10 Apr 2013
Try Paddington to Reading at peak time, then you'll realise how feasible that is!
The local services are rammed, and take double the time.
This is the same situation for MK, LM services can't carry all of the MK passengers.
Why take a slow, rammed LM service, when you can take a quick VT one in half the time?
gordonthemoron
4 Sep 2006
Milton Keynes
What exactly is the point in this? The 19:10 & 19:20 lose about 50% of their passengers at Milton Keynes, a lot of whom will be on Virgin only tickets, so Virgin lose money. Furthermore, MK is more akin to Reading where shock horror, all long distance trains stop
Agent_c
22 Jan 2015
Those extra bodies on short journeys turn into non-revenue empty air after Milton Keynes. The goal is to add more capacity for the higher revenue longer traveller.
They get into a habit on the other days and just look at the time and terminus, not the calling points.
