LOL The Irony
Because all Thameslink trains don't have single end doors like a 156.I'm still not clear why two platforms on Thameslink can manage three times that.
Based on past experience wouldn't they have just built yet another railway line and station which doesn't really connect properly with Piccadilly, Mayfield, Victoria, Central, or Oxford Road?I cant help thinking the Victorians rather than talking would have had 15 16 built by now.
K
And Thameslink also isn't acting as a intercity line (with suburban stock) as well as a commuter line....Because all Thameslink trains don't have single end doors like a 156.
Tram-Trains are not needed on those lines, unless you want to double track Deansgate Junc to Navigation Road. Surely Knutsford (or even Northwich) to Bury & Piccadilly is more ambitious.
That sounds very cheap. It would take more than that to get from the Undercroft back up to BR level.
How many Marple-bound trains run from platforms 13 and 14 compared with those that leave from the terminal platforms in the main train shed...if any?
So maybe an hour late, maximum, into the Airport? I suspect they were cutting it rather fine to begin with if they missed the flight (do you know that or was it speculation?), as you're told to arrive at least two hours in advance for a long haul flight, but can usually get through in one if you're delayed en route. I'd never leave it that close, as you never know what might delay your journey.I was on a Transpennine service to the Airport this week which ended up being over half an hour late at Piccadilly. A couple of Americans on the train who were getting twitchy about missing their flight were quite rightly furious when the train was terminated there thus making them miss their flight.
Well the previous train could have been canceled.So maybe an hour late, maximum, into the Airport? I suspect they were cutting it rather fine to begin with if they missed the flight (do you know that or was it speculation?), as you're told to arrive at least two hours in advance for a long haul flight, but can usually get through in one if you're delayed en route. I'd never leave it that close, as you never know what might delay your journey.
I was on a Transpennine service to the Airport this week which ended up being over half an hour late at Piccadilly. A couple of Americans on the train who were getting twitchy about missing their flight were quite rightly furious when the train was terminated there thus making them miss their flight. Long distance AIRPORT SERVICES SHOULD NOT BE TERMINATED AT PICCADILLY.
Something must be done until the dreadful and incompetent Grayling is removed and platforms 15 and 16 are built. It is obvious 14 trains an hour (through Deansgate) doesn’t work, so these need to be reduced. In addition, as a frequent user of Deansgate it is also obvious that part of the solution is to reduce trains stopping there (4 one way and 5 the other).
So the solution in the shorter term could be something like:
- reduce the number of stopping trains at Deansgate to 2 an hour in each direction (this is in line with Tfgm’s policy with the passenger numbers there)
- reduce the number of trains through Deansgate from 14 to 12 by, say, diverting the Liverpool and Wigan stoppers to Victoria (one of the Airport and Alderley portions of these journeys could connect with the Blackpool Piccadilly terminator, leaving only one extra Piccadilly platform an hour to find).
How do you plan on diverting all the Liverpool stoppers to Victoria without leaving many CLC route stations with no service plus West Allerton and Mossley Hill?I was on a Transpennine service to the Airport this week which ended up being over half an hour late at Piccadilly. A couple of Americans on the train who were getting twitchy about missing their flight were quite rightly furious when the train was terminated there thus making them miss their flight. Long distance AIRPORT SERVICES SHOULD NOT BE TERMINATED AT PICCADILLY.
Really? That's the turn of phrase you're using?The airport services from every shanty town and shack from the north east has knackered it all up.
If the system is only good for serving a compact city centre, then I don't see why you would conclude the system is good enough for Liverpool versus Manchester. Liverpool's city centre isn't compact, but fairly sprawling. And its suburbs perhaps more extensive than Manchester's. Surely serving any large city with trams alone isn't ideal?
No this is simply wrong. There were 2 TPEx services an hour from Manchester Airport to Leeds and beyond before the timetable change that caused all of the chaos.
And yes, I use shanty and shack. What of it?
I meant Regional rather than Suburban - the EMT 158's (themselves often over crowded) seem to take twice as long as timetabled IME with everyone struggling to get on and off a train which is crowded and with stupidly narrow doorways, onto a platform itself overcrowded. The TPE services from Glasgow are nearly as bad (but with a bit more space on the doors). Really does not help that the platform is being used for intercity interchanges as well as local services.As the origin and destination are unlikely to affect loading at a single platform (and suburban stock may load a lot quicker) does that stack up?
Err I am not sure who the question is aimed at! Anyway, to be clear, my comment was driven by your specific mention of the North East nothing to do with shantys or shacks for what its worth.
Apart from issues of door positioning and train length, IMO a more fundamental issue is that a high proportion of passengers on every through train either disembark or embark at Piccadilly. So the passenger flows on the island are much greater than those on most through platforms elsewhere, and indeed greater than those on a terminal platform. At a busy terminal, such as the Piccadilly main shed, arrivals and departures from adjacent platforms are often staggered, so alighting and boarding passengers have more space to spread out and avoid each other. The narrow island has to serve trains at both P13 and P14 concurrently, which increases congestion in the central area and on the stairway.Having suggested banning end door stock wouldn't it be as good or better to ban trains shorter than four cars, six ideally (I think that would fit most of the important stops for a lot of the services). That would speed up embarking and disembarking.
With P15 and P16 operational, the majority of passengers on those platforms would be boarding westbound services, while the majority on P13 and P14 would be alighting from eastbound services. This would greatly reduce platform congestion.
Chaos again on Friday evening on 13/14. The government should just bite the bullet. Regardless of cost to benefit ratio - the government is eventually going to have to spend £1 billion to fix the rail capacity problem through Manchester. The lost productivity being late to work most mornings has a financial cost.
We're asked why it's not like Thameslink. Once so many trains are running late things start to accumulate.
From discussion on the December 2018 Timetable Change thread, part of TPE's temporary mitigation (from Dec 2018 to Dec 2019) will be interworking of the Newcastle and Middlesbrough services at Manchester Airport. This will increase turnround times from 10 minutes to 40 minutes and so should reduce the incidence of terminating short at Piccadilly. But it also might prolong the use of 185s on the Airport services. TPE has hitherto planned to restrict the Mk5A sets to the Middlesbrough and Scarborough routes, which would preclude them working Airport services before December 2019.I agree. Longer units would help reduce overcrowding delays e.g. with 3 coach 185s but the high turnover at Piccadilly is the primary cause of long dwell time. A ban on end door units would be a vast improvement but would need a huge recast of services. An exception could be made for TPE Scotland services but the North TPE services would need to be double 185s or diverted elsewhere. Now that some of the stops added in May are being removed from Piccadilly-Hull why not go the whole hog by removing the rest and opperating it with Mark Vs or 802s to concentrate 185s on services through 13 and 14?
Thameslink has longer trains, stopping in the same place of similar build up and not many freight.High turnover seems to apply on all the Thameslink platforms I've been on, perhaps not as high as at MAN but high. I'm still trying to drill down on the disparity on the number of trains each double track route can manage.
