railsail to Douglas, IOM
ywy1234
9 Jan 2012
I am planning a trip from Oxford to Douglas, IOM next weekend.
I am wondering if we can take the Liverpool to Douglas ferry instead of from Heysham. I think we can, but I don't know why, the liverpool ferry was not on the NRE or Raileasy journey planner.
Thanks!
hairyhandedfool
14 Apr 2008
I have never found it particularly easy to select the Liverpool ferry on Fastis, but I think that could be just a timing issue (journey/connection times). See if you local ticket office (or the telesales dept. of your chosen TOC) can find the journey plan, or call the ferry company and see if they can do it.
34D
9 Feb 2011
It can certainly be done. Booking office would be the best bet.
I believe you have to make your own way in Liverpool.
ywy1234
9 Jan 2012
Is the reservation compulsory for the ferry to IOM ? If I book the ticket online by choosing a Heysham itinerary and try to use that ticket to check in at Liverpool, what will happen to me ?
ywy1234
9 Jan 2012
I even tried to start from local stations around Liverpool, but still NRE only gives Heysham itineraries :(
Any thought?
Eire Sprinter
7 Jan 2012
Hibernia.
There was a detailed one-page article in Today's Railways UK issue 92 about Sail and Rail to the Isle of Man. It recommends to only buy Sail and Rail tickets when the IOMSPC's information line is open and that it is worth taking this number along to the ticket office when booking (08722 992992). In this way if difficulties are encountered with the booking, the IOMSPC can be contacted to double-check availability. The rail booking system could in fact show the ferry as full even though there's still availability.
A particular ferry must be chosen and staff member at rail booking office should issue a coupon or write down the reference number on a piece of paper.
I travelled from Liverpool to the Island around May/June a few years ago and the sailing was very busy, would suggest arriving early for check-in if possible.
The IOMSPC website has the following info:
http://www.steam-packet.com/SailandRail
Info on local travel to Liverpool Pier Head:
http://www.travelwatch-isleofman.org/uploads/5/6/8/7/5687674/passinfo_lpool_0413.pdf
34D
9 Feb 2011
I'd expect you'd be turned away! The boat could well be full.
Just go to a booking office, and get them to do you ferry reservations for Liverpool, if that's what you need.
lyndhurst25
26 Nov 2010
Given that the TT Races are being held over the next fortnight, I'd expect the ferries to be very, very busy. Some may well be fully booked up.
