The highways guys very much do consider roads in isolation!
I await the list of highways closures then, in that case.
Oh no, there won't be, because roads aren't expected to generate farebox revenue.
There’s frequently permanent closures of smaller, lightly used roads.
If you want a big one, let’s go with the A14, Huntingdon.
On a pwesonal level, if it's the viaduct over Huntingdon station that's going, I'll miss it as it was a bit of a landmark of the ECML.
Its gone!
No, but that service (which goes across Manchester all the way to Wigan) has only a few minutes recovery time at Blackburn. If you added four stops each way you would have to put an extra diagram into the circuit. Then the extra traincrew costs have gobbled up your savings - for the sake of stations that probably have lower footfall than the ones you are already proposing to close!...are you forgetting about the hourly Blackburn - Burnley - Rochdale - Manchester service (which could pick up some local stops in your example)?
On the contrary, cuts can most certainly be countenanced, but the cuts have to be to services, not just pieces of infrastructure considered in isolation.But, by what you're saying, there's no line that can be considered in isolation - even one with only a couple of passengers can be explained away on the grounds that "you need to look at the bigger picture" and all of that, everything can be explained away.
We need billions of pounds in subsidy to keep the railway functioning (even at times of record passenger numbers), but no cuts can be countenanced.
What proportion of those billions in subsidy do you think would be saved by closing lightly used sections of the network?We need billions of pounds in subsidy to keep the railway functioning (even at times of record passenger numbers), but no cuts can be countenanced.
I don't see how converting to Light Rail standard isn't still a binary open/closed situation. It's not like the driver's going to make an announcement for all passengers to get off and carry the unit over the next gap. I agree though, opportunities to reduce running costs should be explored if it means locally significant but lightly-trafficked routes could reduce the required subsidy/avoid closure.The difference between road and rail here is that rail is much more binary: a railway is either open or closed. You can't put up a sign at the start of the Conwy Valley saying "Danger, Failed Line", and if the 150 hits a washed-out bit of track halfway down, that's the passengers' lookout.
But does it have to be binary? Should we be looking at converting more lines to a Light Railway standard, with lightweight rolling stock and cheaper signalling? That, to me, is a more interesting question than simply "should we keep these lines open".
Hardly an equivalent to whole towns being deprived of their railway link.
Turnpike trusts started just over a hundred years before railways and only really got going in a big way in the 1750s.A pretty silly statement that, because most of the roads into towns long pre-date the railways by virtue of having been developed from the turnpikes which existed for hundreds of years before the railways were invented.
If you closed all the roads into a town, even if you left a railway in place, you'd basically isolate the town and probably kill it completely, because it would be totally impractical to provide even basic services.
Exactly. The choice shouldn't be "open or closed", it could be "open as heavy rail; open as some form of light rail with standards more fitting to the levels of use; or closed".I don't see how converting to Light Rail standard isn't still a binary open/closed situation. It's not like the driver's going to make an announcement for all passengers to get off and carry the unit over the next gap. I agree though, opportunities to reduce running costs should be explored if it means locally significant but lightly-trafficked routes could reduce the required subsidy/avoid closure.
What savings would you look to make? Reduction in linespeed or Route availability? And what kind of lower-spec signalling do you think would be appropriate? These are the kind of parameters we need to be able to judge whether a line could be kept open as a feeder route or isn't worth the time and cost to keep going.Exactly. The choice shouldn't be "open or closed", it could be "open as heavy rail; open as some form of light rail with standards more fitting to the levels of use; or closed".
