Reading upgrade - Network Rail management?
Ivo
8 Jan 2010
Bath (or Southend)
Sorry if this has been mentioned before, but the term "Reading" is far too common on this site to be able to search for!
Anyway, last time I was at Reading I noticed that at least some of the station signs had been replaced by new disigns that looked identical to those used at Network Rail stations. Is this merely in relation to the upgrade, or is there a possibility that Reading will go over to to Network Rail upon completion of the scheme? Of all the stations that are not managed by Network Rail, it is one of the most prominent...
WatcherZero
25 Feb 2010
I think its just a case of Network Rail leading the massive redevelopment project and using its own suppliers rather than the tocs.
gswindale
1 Jun 2010
Is this not simply a case of the station actually using signs as suggested in the "Improving Britain's Railways" report (or whatever it was called by Lord Adonis) a few years back that recommended that all station signs should be in dark blue with white lettering and if a TOC wanted specific branding it should be underneath the actual sign? This was part of a suggestion to reduce costs in the future when franchises change hands.
Most SWT signs are in this style now I believe.
fgwrich
15 Apr 2009
Hampshire
And South Eastern too, albiet theyve done theres slightly differently.
TEW
16 May 2008
They are definitely Network Rail signs, identical to the ones found and London termini. It makes more sense than installing FGW signs, it might not be FGW running the services by the end of the project.
jopsuk
13 May 2008
It'll be a Network Rail-led project as the sheer scale of the track changes, new bridges etc takes it beyond the scope of something a TOC would do outside of a Chiltern-style "Evergreen" project.
