Everyone - thanks for all information received
I measured the position of the crossover on aerial photography and adjusted it in the diagram to be more in proportion with platform length.
Down Siding [kickback from platforms #3 / #4 (Post Office Dock)] now shown removed.
I was aware of the length limitation in #1 and understand that is why it has two signals at the south end. Points from #1 to #0 are thus already shown starting 'inside' the end of platform to convey this. I wonder whether the platform edge alongside the turnout will now be taken out of use permanently along with the 'outer' signal or will it be left in situ so that in an emergancy a longer train could still be turned back? (albeit blocking access to #0 whilst doing so). The diagram tries to reflect geometry of the existing track shown in aerial photography but cannot be perfect as it's a 'straight line sketch' and not to scale.
The additional connection from #0 to Guildford line is now shown, presumably partially adapted from the former goods loop turnout.
All connections to loops / sidings on Tonbridge line shown removed apart from 'Loco Siding'
Platform #1 shortened a little more.
Can you tell from your information whether the left hand ladder at the north end is being renewed, perhaps in a slightly more southerly position as part of the simplifications, as it seem unlikely from aerial photography that the new right hand crossover will fit between the existing turnouts and the innermost down home signal gantry structure, which I expect NR would not wish to have to renew in a more northerly position if not neccessary, as that would degrade the tight standage clear of the 'outer crossover' and could trigger wholesale recalculation of signal spacing, sighting etc all to modern new build standards etc. (i.e. unseal multifarious containers of cylindrical invertebrates). Hence I've shown the left hand ladder renewed, but am I right?
v3? tentative
http://www.townend.me/files/redhill.pdf
