Renumbering Coaches / Locos
reddragon
24 Mar 2016
Churn (closed)
I am modelling Southern / Western but most coaching stock is Midland / Eastern.
Do you know anywhere where I can get renumbered coaches for less than the £25 per coach charged by TMC?
reddragon
24 Mar 2016
Churn (closed)
I have done it years ago by painting over the old number & using transfers, but modern stuff is very good and I worry!
Peter C
13 Oct 2018
GWR land
I can't think of anywhere which would offer the service off the top of my head. As with @Iskra's post above, it might be best to do it yourself. This video from Chadwick Model Railway shows you how (and how not) to do it:
-Peter
SCH117X
27 Nov 2015
There are various options depending on how the factory has applied the numbers. The easiest were Kader produced models for Mainline, Replica and some Bachmann where enamel thinners will remove them; just watch out out that lining is not damaged. Has also worked on some recent Hornby models.
A seemingly crazy option is simply to rub directly on the digit with a wooden cocktail stick or tooth pick. A version of that is use T-cut as well but I have have never had to.
A further weird version that has recently been found is to rub over the numbers with a Sharpie marker and then wipe both the marker and the numbers away with a brush soaked in acrylic thinners.
An old simple mention that is properly difficult today was to use a typists eraser pencil from the days of typewriters
hexagon789
2 Sep 2016
If you are willing to learn/give it a go if would go with what Iskra suggests:
As I found out myself, you are probably better off learning to do it yourself in the long run :)
I would agree, especially as in my case not only do I have plenty of stock requiring renumbering but some of the stock might not be done by a UK based firm as Irish stock is a bit more niche
Cowley
15 Apr 2016
Devon
I guess I can practice on my older Mainline coaches! Long time since I last tried :)
I think that’s the best thing to try first. I’ve got a glass fibre pencil which I bought to remove digits off something and that worked well.
BRblue33
12 Dec 2020
End of the southdowns
I use a cocktall stick and T cut. Or use a cotton bud . On some lima models you can use Sellotape. Put it over the number rub with a cocktall stick take it off. The number may come off. I've done it this way on a few Lima class 73's. With T cut take your time don't go to hard and take the paint off aswell.
