Reporting numbers on overnight Sleeper
Discussion in 'Allocations, Diagrams & Timetables' started by Dave1954, 9 May 2015.
Thread Status:
  1. Dave1954
    Dave1954 Member
    132
    11 Mar 2013
    I have noticed last night that the N/S bound Sleepers are carrying new reporting numbers, 3 digits and a W , what would the W mean ? I know they are digits but in my opinion it has took the shine off the both sleepers :( Regards Dave1954 .
  2. swills
    swills Member
    502
    15 Jan 2008
    They were 1S25 and 1S26 as far as I can see
  3. Dave1954
    Dave1954 Member
    132
    11 Mar 2013
    Hi Swills , Last night i was viewed 1S25 on the Watford cam it was showing a reporting number as 123W , This morning i checked realtimetrains and 1M16 was running as 122W .......... Regards Dave1954
  4. 221129
    221129 Established Member
    2,667
    21 Mar 2011
    They are randomised headcodes used by RTT etc... They Haven't changed the real Headcoades.
  5. Jonfun
    Jonfun Member
    971
    16 Mar 2007
    North West
    Headcodes are in the format 0A00. First number is the class of train, a letter to indicate information about the train's routing (generally) and then two further ID numbers to identify the service.
    I can't understand why on earth a train running under a different headcode would in any way take the shine off anything.
  6. swills
    swills Member
    502
    15 Jan 2008
    Indeed RTT do not always show the correct details, and such a 'headcode' would not be recognised by staff (or ARS!) rest assured all the hedcodes are as they should be :)
  7. Dave1954
    Dave1954 Member
    132
    11 Mar 2013
    Jonfun ........... Maybe its because im so use to 1Ms 1Ss 1Vs 1Hs not forgetting the 1As . regards Dave1954 :)
  8. Mojo
    Mojo Administrator Staff Member Administrator
    15,727
    7 Aug 2005
    0035
    All headcodes continue to follow this format.
  9. bb21
    bb21 Moderator Staff Member Moderator
    21,716
    4 Feb 2010
    I think Sleeper workings are now in the database that RTT accesses as freight workings, hence the random gibberish. Don't ask me how, they just are.
    You should be able to see the correct reporting numbers if you read the service details, so in that respect, they are unlike freight workings. 1M11/1M16/1S25/1S26 are still the correct reporting numbers for the four trains concerned AFAIK.
  10. SouthStand
    SouthStand Member
    198
    8 Aug 2010
    Why does RTT randomise the freight ones anyway? Is it for security?
  11. Freightmaster
    Freightmaster Established Member
    1,543
    7 Jul 2009
    Commercial confidentiality.
    Freight services are anonymised by scrambling headcodes
    (and removing the two digit FOC operator code) to make it
    as difficult as possible to connect RTT schedules to specific
    FOCs/flows to prevent monitoring/collation of commercially
    sensitive data regarding the number of trains/tonnages moved
    by each FOC to and from power stations, quarries, etc.
    Unfortunately, it also has the side effect of hiding headcodes for
    innocuous trains such as railtours, test trains, mail workings, etc.
    MARK
  12. ANDYS
    ANDYS Member
    200
    21 Feb 2011
    Chesterfield, Derbyshire
    Can anyone shed any light on why GBRf headcodes show on RTT?
    Anyone who is that interested / knowledgeable can work out who is operating a service can very quickly.
    Andy S
  13. Freightmaster
    1,543
    7 Jul 2009
    Frontline GB staff have started using RTT on their mobile devices
    (presumably cheaper than paying for Genius mobile licences?! :shock:),
    so GB asked NR to stop scrambling their headcodes.
    But I think its very unlikely that the far more secretive DB, FL
    and (especially) DRS will follow suit, though!
    I would dispute that.
    In many cases, I agree that the destination/origin of freight services
    are handily appended with the name of the FOC these days, but that
    isn't always the case, so unless you already know who operates a
    particular train/flow, you can't reliably work it out from RTT,
    which is the whole point of the anonymisation process:
    https://ico.org.uk/for-organisations/guide-to-data-protection/anonymisation/
    Also, there are occasions where the locations displayed on RTT can
    be misleading, such as Whitemoor yard/VQ, which always shows as
    Whitemoor GBRf, even for trains operated by Colas/FHH, because
    GB are the operator of the yard.
    There are many other, similar examples elsewhere in the country,
    so to reliably indentify the operator of all freight services,
    including the hundreds of STP/vSTP movements which run
    every day, requires a vast amount of additional knowledge
    and information not available in any of the open data feeds.
    As long as that remains the case, the FOCs will be happy
    that the finer details of their operations remain confidential.
    MARK
Thread Status:
Share This Page
