Possibly, but it'd be very much it's own attraction and not a route for people to get into the peaks.Could the heritage line ever (economically?) be extended from Matlock through to somewhere in the near vicinity of Bakewell once again?
Could the current heritage line ever (economically?) be extended from Matlock through to somewhere in the near vicinity of Bakewell once again?
I'd suggest branching off the old alignment soon after the north portal of Haddon Hall tunnel, dropping down into the Bakewell showground area for a new terminus site close to the town centre, with no impact on the Monsal trail at all.Possibly, but it'd be very much it's own attraction and not a route for people to get into the peaks.
Thanks for clarifying. That somewhat kiboshes things!Their big issue is the missing bridge over the A6 at Rowsley - and the road's been realigned since the bridge was removed. That's not going to be either easy or cheap.
Would the referred-to line to Buxton from Millers Dale take the line that passed through the now-closed Blackwell Mill Halt railway station?
History repeats itself.I'm sure I read somewhere that the current owners of Haddon Hall - which the railway runs underneath - aren't supportive either.
The Duke of Rutland wasn't particularly enthusiastic about a view of the railway from his property at the time of construction either, hence the proposal for a tunnel under the Haddon Hall estate, much of which was constructed using the cut and cover technique. The tunnel probably wouldn't have been required at all otherwise.I'm sure I read somewhere that the current owners of Haddon Hall - which the railway runs underneath - aren't supportive either.
Yeah, in terms of ridiculous financial unviability combined with low demand you're right.Far from the most idiotic - the Dumfries-Stranraer proposal hits this for six
Such as the settlements once served by the Wick and Lybster Light RailwayBut just imagine a world where somehow, believe it or not, it was possible to restore Dumfries - Stranraer. It would have a positive effect (yes limited, but still positive) by improving the public transport connectivity of some small settlements in a remote region of Scotland.
By contrast, if the Peak line was restored, the impact would actually be negative. It would impact people's physical and mental health by discouraging walking and cycling on a popular existing route, and it would damage the ecology of a series of valuable nature reserves.
That is exactly what MEMRAP proposals seek to do, including the vast amount of products from the quarries heading south, currently moved by road due to the convoluted routes trains to the south have to take..In spite of what the naysayers say (and they seem to be multiplying on here for some reason) this is the most sensible of the reopening proposals.
However rather than concentrating on just one market, it needs to embrace all the various traffic flows that will benefit - local residents, tourists and walkers, better inter-regional services between the North West and Midlands and relieving the Hope valley of its freight pressures.
Can you advise what these ‘vast amounts’ are?That is exactly what MEMRAP proposals seek to do, including the vast amount of products from the quarries heading south, currently moved by road due to the convoluted routes trains to the south have to take..
Normally I am very much in favour of rail restorations as a vital tool to support modal shift away from private cars. In fact, I'd probably even support a simple extension from Matlock as far as Bakewell if that was a viable prospect. I just can't get any enthusiasm for this particular scheme. The Monsal Trail is a place I've visited many times and I think putting a railway there would do more harm than good.In spite of what the naysayers say (and they seem to be multiplying on here for some reason) this is the most sensible of the reopening proposals.
Dumfries serves nowhere near the sort of population or tourist market that this route would serve.
If people want to walk or cycle, they will find a way to walk and cycle - just look at the Settle and Carlisle line where they haven't had to pave over the line to get people to walk and cycle - people use it to get to their place of walking or cycling.
In terms of ecological impact, as with Dumfries, both routes have previously been excavated and disturbed by construction, so the impact of both would be minimal - far less than new construction projects such as HS2 and the many road schemes going ahead.
There is no 2 track railway which has been able to effectively handle the competing demands of medium / long distance high speed services, local stopping services and long, reasonably slow heavy freight services.
MEMRAPs proposals fail massively because of this - they are ignoring a few basic facts. Their campaign is entirely predicated on "there used to be a railway here, we don't think it should have closed, ergo it must be reopened following the same route" - if there is genuine demand for a new line from the Buxton area through the Peak District national park, then why not work out what the traffic flows are, which are most important and identify a new route which is fit for purpose - unlike a Victorian alignment, which as ever with the Midland is sub optimal due to its gradients and curves which are far from ideal.
Their proposals also overlook the fact that once these "new flows" get south of Ambergate, they then need to go somewhere else, on lines which already have most of their capacity spoken for - so again, it really doesn't solve any problems and if anything creates more.
Bit in bold - it really isn't.
It's somewhere in the area of sensibility of reopening the S&D or GCR.
Sensible are lines which actually solve problems and might even cover their costs from a revenue side and not create a bunch of problems elsewhere - this fails on all of those.
Sensible reopenings might be things like Leicester - Burton, Isle of Grain, possibly Aylesbury - Calvert to enable Aylesbury - Milton Keynes.
You're probably right. But given that it did close and took on new uses, we are where we are.I think that if this railway hadn't been closed, no one in their right mind would think of closing it. It would be too important to close.
If it were open, it would enable people to visit places throughout the Peak District.
It might just be me at the old age of 78, but I cannot recall a time when there were so many media adverts for "cars of the future"Normally I am very much in favour of rail restorations as a vital tool to support modal shift away from private cars.
And all driving on totally empty streetsIt might just be me at the old age of 78, but I cannot recall a time when there were so many media adverts for "cars of the future"
A credit to a rolled-out new roadbuilding future, especially on the line of defunct railways.....And all driving on totally empty streets
You destroy your own argument in your first sentence:
Two track railways often have to juggle competing traffic flows - freight, fast and stopping passenger trains etc. Just look at the Hope Valley which is the text book case of this.
However two track railways manage this juggling act so much better when there are alternative routes for the different trains to take, which is what the MML through Bakewell would do.
No - my argument hasn't been "destroyed" - I'm stating a basic fact which many others point out, but some people seem incapable of comprehending as you've just demonstrated.
Those competing demands mean compromises - which means a loss of efficiency or effectiveness.
That is what advertising agencies thrive upon and leads to a specific thread on this website where annoying TV adverts make for good posting numbers.And all using incredibly pretentious, pompous advertising.
You have destroyed your argument because you can't remove or lessen those inefficiencies by not having the railway in the first place.
Reinstating the MML through Bakewell would reduce those inefficiencies on the surrounding network - which, in case you hadn't noticed, is mainly two track railway.
How? as I noted earlier, its all very well taking it in isolation, but do all the extra trains fit at either end, where are they going etc.. how does this make those parts of the railway more efficient?You have destroyed your argument because you can't remove or lessen those inefficiencies by not having the railway in the first place.
Can you put some numbers on the services you anticipate on the Hope Valley and the High Peak routes after reinstatement? It's all very well declaring that it will reduce the inefficiencies, but skilled people have looked at this multiple times and said it wouldn't, so obviously it's not readily apparent and they've missed something that you've seen.Reinstating the MML through Bakewell would reduce those inefficiencies on the surrounding network - which, in case you hadn't noticed, is mainly two track railway.
I'd totally agree, and when Peak Rail was formed it wasn't unreasonable to consider getting it restored but in 50 years the world has moved on. Not the least of that movement is the massive loads of limestone and cement being removed in ever longer trains.I think that if this railway hadn't been closed, no one in their right mind would think of closing it. It would be too important to close.
