tbtc
Thus repeating the folly of only considering current travel patterns...
Fair enough if you can't think of any potential flows that justify more than a single track connection between HS1 and HS2.
It's pointless asking people to define something which does not exist today. As has been repeatedly pointed out to you; it's not about travel patterns which may or not exist today - it's about the travel patterns that will become possible in the future.Fair enough if you can't think of any potential flows that justify more than a single track connection between HS1 and HS2.
The M25 planners did not foresee the travel patterns that exist today - and I don't just mean the number of motorists, I mean the sheer variety of new journey opportunities it enabled. Thus we now have the never-ending and exceedingly expensive game of catch-up as they try to add extra capacity.
Don't make the same mistake with the HS2-HS1 link.
A point I have made to tbtc many times now - but one he seems unable to grasp...The M25 actually made it possible for many more people to travel to work east-west or north-south where it was previously impractical
The problem remains that anyone boarding an international train north/west of London would have to go through border controls and especially security, which means these trains could not also act as domestic trains. As well as the huge cost of these facilities at other stations, this makes it impossible to combine international and domestic on the same train, which may be the onliy way of getting a worthwhile frequency.
Trains terminating at Stratford can't go to Temple Mills as the depot junction is at the London end of the station. In any case to turn back most of the HS2 services were turning back you'd need something bigger than Temple Mills with a double track access. I'm sure space could be found somewhere such as around Dagenham.
But not identical. Units could split/join at Birmingham Junction - or other locations as future HS lines are developed. And (as has been pointed out to you before) Stratford Intl will be a busy HS station - if the direct HS2-HS1 services are provided.I've tried to explain the fundamental difference between a road and a railway to you - for a (400m long) train service to work you need hundreds of people making similar journeys.
3) I understand access at Stratford to the depot is via a ramp through the station exiting at the eastern end. Some works would be required to allow passengers to board/alight from trains moving to the depot for reversal servicing. Additional depot access trackage would be a modest price to pay compared to what is planned.
Apart from these points of detail, does the HS London Central concept resonate with you, or is perpetuating the traditional dead-end terminus at the fringe of London's Commercial centre the way to go?
As you can tell, I very firmly believe the current, slightly modified plan will leave a very unhappy legacy to future generations to sort out. The most critical will be the NLL which scarcely needs more constriction of capacity!
Noted, but not relevant in the context of UK domestic services.Split units are not currently permitted in the Chunnel
What constriction of capacity? By adding a third line to Camden Road Jct the NLL and link line will be operationally separate
No, there was one which detailed how the International (UK Border Protection) facilities were to be provided at Birmingham and intermediate stations incl Stage 2. I don't think they had OOC in mind, nor do I.{snip}
There are numerous HS2 documents and I've probably skimmed all of them at one time or another. If you're referring to starting International trains at Old Oak then I see little point in doing so as a better transfer between Euston (or Euston Cross) and St Pancras would only take a little longer than changing at Old Oak, and would give a much wider choice of services because they would also be serving the much larger market that doesn't want to go via Old Oak.
{snip}
This assumes a pair of extra tunnels can be bored into the station box at Stratford International which was never AFAIA designed with this mind - seeing as the practicality of even one has been questioned in the past, and in the latest refinements consultation a tunnelled option was described as having to reach Barking, this doesn't appear to be achievable.
Chris
That may be your opinion. It seems it is not the opinion of HS2 Ltd.But that would mean that international trains from Birmingham etc would have to carry only international passengers, or any domestic passengers on these trains would have to go through security and passport controls. In my opinion the international traffic is not enough on its own to justify a train service, so would only work if combined with domestic traffic, hence these rules kill the idea.
With HS London Central, HS2, LU, CR2 and other domestic passengers can exit to St Pancras International Border Control DIRECTLY, and formalities completed, proceed to the assigned international departures platform (or if early, to lounge facilities in St Pan.)
Why? Schengen wouldn't relax tunnel security requirements any more than it does for air travel. Passport checks alone take no time at all so as long as security checks are deemed necessary for tunnel transit, there are no meaningful advantages.international trains would be so much eeasier if we were a Schengen country. Pity the bampots will prevent this happening.
After spending over 45 mins queuing to get through passport control at the Port of Tyne the other day, I'm not inclined to believe you...Passport checks alone take no time at all
The security checks are the bigger problem to be honest, you could just do passport checks rolling en route to the Chunnel and stop the train at either Calais or Ashford International to make sure anyone without a passport got off.
I've traveled numerous times on Eurostar and passport checks have never taken more than a few minutes. They can be long winded at airports, but only when a number of flights arrive at the same time.After spending over 45 mins queuing to get through passport control at the Port of Tyne the other day, I'm not inclined to believe you...
Not really - the constriction will be on future options. If the work is done on the viaduct to reinstate 4 tracks but is instead used to slew two northwards so 1 larger one can use the southern alignment, then it's still a constriction of capacity.
To go though the expensive of widening the bottleneck for a measly 3 tpd when the same widening works would enable a projection of the ELL from H&I up the DC lines is madness. If the NLL can mange with just the two northern tracks, then by all means slew it and restrict it to them, but use the vacated space for two more ELL tracks!
I'm not assuming an extra pair of tunnels into Stratford. The junction for the HS London Central (Euston Cross, etc) would be near Dalston, and underground (Discussion on this point at District Dave's).
Has anyone bothered to work out what will happen with HS2 - lots of long tunnels there and of course HS1 tunnels under the Thames so why don't we carry out baggage checks on Kent pax?
Surely it must be clear that this nonsense of checking baggage for the trips under the channel - only, and then only on rail pax, not car pax or HGVs, is totally illogical.
