One running line is 20% of the station capacity!
The whole point of HS2 is to create more capacity on the WCML, so the last think you'd want is a bottleneck on the busiest section. However a connection to send some of the WCML semi-fasts through Crossrail would relieve pressure here.
Having a dedicated link does have some advantages in that it allows the ISIS-320 measurement train to potentially cover HS2 as well as the French network, avoiding the costs of purchasing an additional measuring train for the Captive Network.
Additionally it allows new rolling stock to be delivered by rail, permits trains to return to the continent for heavy maintenance and does allow us to plan for the possibility that some international services will be wanted in the future.
It is a hedge against a possible future demand and also provides various operational advantages.
Could the route that is presently used for freight between the Channel Tunnel and the West Coast Mainline (the Maidstone East line and the West London line) be used for such purposes as a HS1-HS2 link (not passenger services)?
Well, the thread started with this:So, after a couple of hundred posts, nobody has given any evidence of demand for frequent links between HS1 and HS2 ...
The rest is baseless speculation as to what it was that Jim Steer found. Or didn't find.Greengauge21 director Jim Steer said: We have identified a substantial demand for domestic high-speed rail services over the proposed link connecting HS1 and HS2. ...
Quite apart from the problems of connecting it to HS2 in west London somewhere, this would only be useable by UK gauge trains operating on third rail, so wouldn't be any use for swapping Euro-standard trains between the UK and the continent.
Haul it using a class 92 from Ashford to Watford Junction and then send it back down to Euston and then on to HS2?
That does not address the difference in loading gauge.
Chris
The gauge of the route is W9.
no - it will surface to use the Primrose Hill - Camden Road - HS1 pre-existing link, though would alter it.Is the cucrently plan a single track/bore tunnel all the way from OOC to HS1?
Read upthread that the 3tph each way is way way more than enough.That seems ridiculous - and the longer the single stretch, the less flexible.
No - maybe they could move the junction underground (at, say Queen's Park, rather than OOC), but I'm not sure that would reduce the cost. It must surface to go through Camden, or it would be very difficult to plug it into HS1 after passing under the Northern line.Could they not build a quick tunnel spur from the HS2 line in the Camden area, and link in directly to HS1, meaning the single bit is very short and thus could handle more tph? Cheaper too.
But one would imagine that the link - especially when the costs to the local/freight network through Camden is considered - would cost more than a measuring train. And anyway, the additional mileage of the measuring train's route would cause issues. And loaning the train from the French would cost money.Having a dedicated link does have some advantages in that it allows the ISIS-320 measurement train to potentially cover HS2 as well as the French network, avoiding the costs of purchasing an additional measuring train for the Captive Network.
Oh, absolutely, however the reopening of the Primrose Hill link to passenger service, increasing frequency on the Overground (and thus needing a wider alignment through Camden) seem a much more sensible bet.Additionally it allows new rolling stock to be delivered by rail, permits trains to return to the continent for heavy maintenance and does allow us to plan for the possibility that some international services will be wanted in the future.
Though is also a hedge against the need to finish the Overground expansion/upgrade planned and mostly carried out a couple of years ago, with the final bit ditched due to the cost of widening Camden in the middle of a recession with lots of spending cuts...It is a hedge against a possible future demand and also provides various operational advantages.
The operational advantages are a much better way of selling it than potential trains bypassing zone-1, but do the benefits of the link outweigh the dis-benefits to the local rail network through Camden? do they outweigh the cost of building the link? Put simply: is this waste-of-money merely hidden by the usefulness of spending on the rest or does it justify itself, unlike a short link near Warrington for faster Liverpool trains, or a Heathrow branch?
Sure, I'm playing a bit Devil's Advocate, but a costly (and not just financially) scheme merely for (rare) stock transfers and the (bi-weekly?) measuring train, seems rather a white elephant. Add to it scuppering local services in one of the local areas most angry about the scheme - Camden (though that is more due to Euston) and it surely struggles to justify itself as an isolated portion.
The plan has always been to use a combination of new tunnel, from OOC to Primrose Hill, and then existing track over the freight only Primrose Hill line and the NLL through Camden Road - however the single track link line will now be dedicated to High Speed services, by adding a third track to Camden Road Jct and so segregating it from the NLL. The latter will also gain a third track through the station east to the freight loops.
There's a summary of the current proposal and the latest changes in Consultation Document - pages 21-24
Chris
By the time HS2 is built, the NLL could well be using ETCS (certainly if we really wanted it to) in which case perhaps it doesn't need to be segregated at all.
By the time HS2 is built, the NLL could well be using ETCS (certainly if we really wanted it to) — in which case perhaps it doesn't need to be segregated at all.
There is a way UK gauge and GC+ can use the same platform if a little extra width is available. (as forseen by IKB ) It involves parrellel rails and points. How do trams and trains use the same platform?
It's not an issue of signalling, indeed the original proposal had conventional services sharing the link line through Primrose Hill and Camden Road Jct, but due to objections from TfL and Network Rail the latter has gained a third track to allow segregation and so avoid the reliability issues that would arise from mixing conventional services with those using a single track bi-directional link line.
Chris
All stations would have to be segregated as a Euro-gauge train can't pass a platform that a UK-gauge train can stop at.
If they were mixed, there wouldn't be any bidirectional!
So just Camden Road then? I guess it could always be converted to have a retractable platform edge, should demand ever require a higher HS2-HS1 throughput — which makes the current single-line plans a lot less concerning.
