Reving trains.
12 Nov 2008
Throttle on then off, same as a car really...I think lol, I dont think you can rev units as much, locos im sure can be reved
GNERman
8 Oct 2008
North Yorkshire
yeah, reverser into neutral, brakes on and give her power, I did that to 37901 at neville hill...
ralphchadkirk
20 Oct 2008
Essex
There are some instances where you would want to, but I can't recall them at the moment.
HSTfan!!!
11 Jun 2005
to **** of punters and make them run ;) works a treat usually
some units have a rev up button afaik - I'm aware of it on 170's anyhow
mumrar
26 Sep 2008
Redditch
Most diesel units, certainly the sprinters and turbostars, have a compresser speed up switch. This is used to build up air in the main reservoir for brake release. If a unit spends a long time shut down, then air pressure can drop below the threshold for brake release (between 4.5 bar and 5.5 bar). So in the mornings, and if a unit has turned around after a long time, you'll hear them revving up to get pressure increase.
37401
12 Nov 2008
Heard it a few times, best thing is the passengers reactions "Its moving with the doors open" :lol:
red circle
1 Jan 2010
near Ongar
If you opened the controller in EO on an un-refurbed '37 the engine ran up faster than the governor could catch it and the overspeed trip operated.This had to be reset and that lever had the strongest spring you could imagine behind it.
GNERman
8 Oct 2008
North Yorkshire
that's why they do it, i've noticed it on 158's and 185's at york station quite a lot, not knowing why though...
TDK
19 Apr 2008
Crewe
Is it possible to rev a train? If so how do you do it?
There wouldn't be a reason to rev up an engine manually, it can be done but it is a pointless exercise unless like some you get off on the sound of a diesel engine screaming. I can't think of any driver who would rev up an engine for no reason.
The compressor speed up is a toggle switch to rev the engine on a unit to build up the air quicker, fyi you cannot get a brake release with the compressor speed up on, the have to switch it off to get the brake.
Vulcan
10 Dec 2009
Seaton, Devon
Narrow gauge engines are easy to rev pointlessly, but when they are mostly fitted with low revving engines its neither interesting or good for them.
ungreat
11 Nov 2006
And why would anyone (other than a Jeremy Clarkson wannabee) want to?
Freight trains often rev the engine to charge up the brakes on a string of wagons that are dead air wise quicker...I know,I used to do it lol
37401
12 Nov 2008
HSTfan!!!
11 Jun 2005
ah thats the one fella! lol I wondered what it was called doh!
37372
24 Jul 2006
Mexborough
I've seen a lot of units get revved up at Sheffield just after they've been started up, probably to warm the engine up. It can get very loud!
feliner
20 Nov 2009
Wakefield
A class 66 will rev up on its own when the main air gets low, one can look a bit of a plonker approaching a red signal with the loco,revving away.
