Route coding problem!
Harold
9 Jun 2005
Southampton
Hi all, I am during the process of coding Havant for my non-fictional probject for BVE 2 and 4.
The problem I'm having is, I have created the object textures for my track and station platforms, I put them into the .b3d files, changed the old names that the .b3d files had to my new named objects, and when I code them into my route, BVE says that there is missing object textures depsite the fact there isn't and that my objects are in the same place as the .b3d file that contains the file name for the object name I am using.
Someone please help :(
The Snap
10 Jun 2005
Hmmm, are there any full stops or slashes in front of the objects texture name? Or, is the 'Loadtexture' bit spelt right etc? ;) :?:
Tom B
27 Jul 2005
Evidently the textures aren't there! Check the objects in structure viewer. If that works check your slashes are the correct way round - remember that under DOS a backslash is used to signify directories.
Coxster
9 Jun 2005
Having looked in Structure Viewer, it appears you have used an old file (with your own copyright message at the top?) so I am guessing you don't have your BMPs the same size as the originals that you have replaced. The file is set up so that the BMPs must be in the same folder as your .b3d file.
Guinness
13 Jun 2005
Actually they don't. Take a look at some of X-City objects then you'll see what I mean. ;)
Tom B
27 Jul 2005
If you use Unix convention rather than DOS convention (slashes rather than backslashes) when referencing the object, it won't let your objects reference to other folders.
The Snap
10 Jun 2005
Yeah, that's right Chaz! :) Also, you MUST make sure that the images are of specific sizes. I think it goes
64x64
128x64 (or the other way round)
128x128
128x256 (or the other way round)
256x256
256x512 (or the other way round)
I think that is as big as you can go. :?: But, they MUST be of that size, or BVE will not read them, and they will come up all fuzzy, and sometimes not even appear. ;)
Coxster
9 Jun 2005
The way Harold has set his one up he just lists the texture as 'x.bmp', not '\...\xxx/xxx.bmp' or '/xxx/xxx.bmp' so in his case they must be.
Tom B
27 Jul 2005
They're not ther only ones - you can have any side length that is a power of 2. As for the maximum I've had 2048x2048 textures before!
You can get away with other sides, but they're not reccomended as they are only compatible with certain gfx cards.
Coxster
9 Jun 2005
The Banstead bridge in my route was originally not a correct size limit so the transparent bit only appeared as solid black. Re-sizing the textures didn't affect it's appearence much either excepot obviously making the underneath transparent as wanted.
Harold
9 Jun 2005
Southampton
Success, it worked!
It seems Tom and Rich were right, I had the dashes forwards instead of backwards.
Thanks guys!
Coxster
9 Jun 2005
Harold said:
Success, it worked!
The file you sent me didn't have any slashes and was just set up to have the bitmaps in the same folder as the .b3d file...
Coxster
9 Jun 2005
Chaz said:
Small Platform. Is it ment to be a Halt?
No, Havant mainline station on the Pompey/Soton/Eastleight to Waterloo/Brighton/London Victoria lines (West Coastway) ;) The LSWR concrete platforms were sometimes slim but look at the yellow line on that ;)
29 Jul 2005
Ooh I'm familiar with Havant station as my grandparents live there....! Looks pretty realistic to me! Which route will it be part of?
Harold
9 Jun 2005
Southampton
Hi LankyLancaster,
My non fictional project I am working on is Havant to Fratton for BVE 2 and 4. I travel between these 2 days during weekdays to get to college, so I thought "why not" make a BVE route out of it, I am progressing slowly now, thanks to Coxsters help ;)
More screenshots will follow as progress continues.......
29 Jul 2005
Oh fair enough, should be a nice little route once completed, I look forward to it, it will be the first non-fictional route that I am totally familiar with! :lol:
Presumably your 444 will run on it?
Harold
9 Jun 2005
Southampton
Indeed it will, the 444's current state is trying to get the Motor sounds to work efficiently and to work on the BVE 4 cab.
