Route Vadility Question
Slough
13 Apr 2012
Hi
If I have a open return from slough to Eastbourne , and an anytime return from Lewes to Brighton am I able to do the following on the outgoing ticket
Slough to Victoria via Paddington and underground this is valid so no problems But then
London Victoria to Brighton getting the fast train that stops at east Croydon then fast to Brighton
Walk round Brighton for a bit
Then Brighton to Eastbourne ?
34D
9 Feb 2011
Hi
Sadly not on a fast train: the train would need to stop at the station where you change tickets - national rail conditions of carriage clause 19.
philjo
9 Jun 2009
East coast website will let you buy a Slough-Eastbourne ticket travelling via Brighton on a fast train from Victoria so I don't see a problem with this.
As far as I can see going via Brighton is valid on map LB in the routeing guide
(Slough & Lewes are the routing points in this case - the routeing combinations given are LONDON or RG +LB). from London LB is one of the options.
calc7
8 Aug 2011
I was going to say, I'd be suprised if London - Eastbourne is not valid via Brighton.
I can't tell if by "open return" you mean Anytime Return (in which case Break of Journey en route is always valid) or Off-Peak Return, whose validity code for this flow does not prevent BoJ anyway.
