John @ home
- Joined
- 1 Mar 2008
- Messages
- 5,148
I wouldn't say you've got anything wrong, but you have made a couple of assumptions which may or may not be correct.Anyone think i've got this wrong in any way?
Here, you have assumed that it's appropriate to compare season ticket prices when analysing route availability with a season ticket. But the Routeing Guide Instructions state:I then narrowed the discussion to season tickets ... At the new prices the seven day seasons (7DS) cost:
route Redhill £72.40
route not via Clapham Junction £62.30
route not via London - no season ticket priced
route any permitted (cross-London) - no season ticket priced
to zones 2-6 route Woking/Clandon £88.30
If the word "All" is to have any meaning, this would direct that single fares are used in the calculation, not season ticket prices.National Routeing Guide said:All fares comparisons must be made using one of the following single ticket types:http://www.atoc.org/clientfiles/File/RSPDocuments/instructions.pdf
- Standard Open Single (SOS)
- Standard Day Single (SDS)
- Saver Single (SVS)
- Cheap Day Single (CDS)
But this particular instruction was re-written around 2008. The previous version was:
You are probably in a good position to find out whether it was apparent to the author of the 2008 version that the wording introduced a new rule that valid season ticket routes are determined by comparing single fares.National Routeing Guide said:All fares comparisons must be made using the same ticket type.
If the customer requires a Single then Single fares should be compared. If the customer requires a Saver then Saver fares should be compared.
Another assumption is that it's appropriate to compare current ticket prices when analysing route availability. But it has been pointed out on this forum that the software used to determine route availability continues to use fares from over 15 years ago (NFM 64). It has been suggested that this has been done to avoid introducing anomalies when one TOC increases fares at a different rate from a neighbour. In a marginal case such as Guildford - Croydon, this may make a significant difference.
I'll end by making a plea for easy access to NFM 64 information online. We've tracked down two paper copies available for public inspection: one in the library of the Office of Rail Regulation; the other in the National Railway Museum. We need better than that!
