Run Sounds in Routes
The Snap
10 Jun 2005
Hi guys,
I was wondering how you make a train run sound be heard at a certain point. For example, when running over two rails which join (ie: a set of points made with two rails), you hear the flange sound or other sounds which sound like the train is going over points. But, when you use a proper point set made by SWITCH, and use that, rather than two rails diverging, no sound is heard, so is you couldn't see the screen, you would think you were just running normally, over no points. Do you see what I mean?
I wanted to get a noise to be heard while crossing over a set or SWITCH made points, as none are heard ATM...? :(
Thanks,
Tom B
27 Jul 2005
Set up a blank rail, and make that cross your rail where you want the sound.
The Snap
10 Jun 2005
Yeah, I will do, I thought of that, but forgot to include it. ;) Thanks for that Tom. :)
