QueensCurve
- Joined
- 22 Dec 2014
- Messages
- 1,926
I did check!
http://www.urbandictionary.com/define.php?term=dreek
Maybe it's how the Americans spell it...
Definitely Dreich.
I did check!
Definitely Dreich.
Americans think McLean is spelt MacLaine. We can ignore them!
I thought only 3 portal-style masts up on the long Ratho viaduct was rather odd.
But from a train you can never tell what is going on below the parapet in such cases!
The bases being installed high up in the deep cuttings look to be large projects in themselves.
In the north west, "masts" were in some cases bolted directly to the rock walls in cuttings (so avoiding the need for bases).
I didn't see any sign of any of that on EGIP, and there's lots of rock cuttings.
I did see some bases on the platform at Falkirk, but otherwise the stations are untouched.
I passed under the Ratho viaduct on the A89 last night, above which one of the masts has been installed. There are some base plates in place on the sides of the viaduct, no sign of ongoing work in that location but there is a works access which leads to a track alongside the viaduct which I imagine is for the electrification works.
Masts have appeared on the viaducts in this part, as well as a portal installed at Lenzie station at the West End. So presumably this was a trial for other stations, which don't have any yet.
Anyone know when East Kilbride line will get electrified?
Regarding the East Kilbride line, I have heard about various proposals and suggestions in that would be an ideal route to convert to tram operation, in addition to the Cathcart District Railway.
Does anybody know if it will be likely to ever happen, or will both routes remain as conventional heavy rail?
It would be the starting point to bring back trams to Glasgow. After all, Sheffield, Manchester, Birmingham, Croydon, and Nottingham have brought back trams.
Given the high passenger numbers and frequent use of 6 coach trains in the peak it seems likely EK would have one of the better business cases for electrification and certainly frees up more DMUs per track mile wired than any other scheme in Scotland.
Edinburgh brought back trams.
Having watched the fiasco from the other side of Central Scotland those in Glasgow and Strathclyde might be somewhat wary of trying a similar project - particularly when Glasgow has a much much more extensive suburban rail network - and where the type of money spent in Edinburgh might be better invested.
I don't understand the eagerness that some people have to downgrade the rolling stock on parts of Glasgow's suburban network. Cathcart Circle and East Kilbride will likely see frequencies doubled in future, so they'll have turn up and go frequencies without losing all the advantages of heavy rail.
Anyway, as Scotrail is introducing brand new EMUs, with toilets and everything, on the Cathcart Circle it looks like the idea of converting it to tram trains has been binned. No one is going to tell passengers their comfy big well equipped trains are being replaced by less well specified trams.
Conversion of the Cathcart Circle line to light rail has been officially included as a possibility in various official reports over the years. It would represent a relatively cheap way to increase capacity into Central HL, while allowing a relatively population-dense area of Glasgow to have a proper rapid transit link into the city centre. Whatever frequencies might be possible on heavy rail, it would be possible to have even higher frequencies with tram-train conversion while reducing operational subsidy.
Has it ever been said where the light rail would branch off? Looking on a map, it's hard to work out where it could be routed without a fair bit of demolition or a lengthy route into the city centre. Presumably it would need to leave north of Pollockshields East, which limits it a fair bit.
Class 385s will be put on the Cathcart Circle because it's the most cost-effective way to replace the 314s. 100mph regional EMUs aren't perfectly suited to the route but they'll manage just fine, and it's efficient to have only one new fleet of trains rather than two. If Abellio had gone with the option of inner-suburban AT100s - which could have been built at the same time as and maintained alongside the AT200s - then it would be more implausible to suggest that there might be changes in future for the Cathcart Circle line. Now, with standard 385s used, these could easily be cascaded onto the other routes (e.g. East Kilbride) when changes are made to the Cathcart Circle line.
A tram-train scheme would most likely be a Transport Scotland project rather than a Glasgow City Council one, so the political difficulties in giving money to a council to build a tram line won't be the same. The justification for this is that at least initially, the job of this scheme would be to relieve the NR network rather than to provide a light rail network for Glasgow. The ScotRail franchise holder could even be responsible for running it given that most of the route kilometres would be on tracks which would have to remain part of the NR network. The Cathcart Circle line would still have to be able to act as a WCML diversionary route and the Anniesland route would see freight and passenger services heading up to the WHL which couldn't be redirected through Partick forever.
If the SNP are re-elected then there won't be any Transport Scotland led tram train schemes.
I still think a north south tunnel is the most likely scenario for future capacity increase at Central.
I don't think it would be politically justifiable for the SNP to ignore the most likely outcome of a Glasgow terminal stations capacity report. The tram-train option would provide a few more years of capacity and would provide enough time for a tunnel to be built properly. Crossrail 1 has been extremely effective so far because its main route has been settled for so long, and so there has been plenty of time to do ground investigations and further design work to come up with the optimum solution. The longer a Glasgow cross-city tunnel can be in the planning/pre-construction stage, the better. With a later deadline, there is more time to go around filling up some of the disused mineshafts which cause so much of a problem for tunnelling in the city.
