For TGV drivers, on LGV, if it is a straight neutral section, everything is done by TVM - advance warning of the neutral section is given in the TVM display, the breaker is opened before and closed after - no intervention from the driver is needed. Although it is not good practice for a driver to motor through on full power without backing off, it is possible to do so and *should* cause no harm. If they are driving multiple TGV's or a Eurostar with two pans raised, each power car with pan raised is done separately as it arrives at the section.
If it is a change of either voltage or configuration (LGV to French Classic for example - which are both 25kV, but require different pan settings), the driver must back off the power to "0", open the breakers, drop the pan(s), coast through the changover area (which may or may not include a neutral section), reconfigure their desk controls, and raise the pan(s), finally closing the breaker when given permission to do so. Unike the above scenario though, the whole train is done at the same time. This can be done at line speed.
TGV's and non-North of London Eurostar sets do not have APC receivers.
