Gemz91
The long title is Locomotive Cleaner, and it's fairly literal. You are there to clean the locomotives, which invariably means getting covered in various types of oil, paraffin, grease, crud etc. Also cleaning the ash fromthe smoke box and ashpan (which, depending on design, invariably means you're underneath prodding at it and raking it out, usually with fire burning on the grate above)
As a cleaner I ended up doing various other bits but you're primarily there to clean locos and help with their maintenance. As it's the first rung on the footplate ladder the thinking behind it was as you worked around the locos with more experienced people, other cleaners, trainees, fireman, drivers, fitters etc you would learn what each bit is, what it does and how it all works together.
Cheers for the quick reply.
