And a lot better for user vibration levels!The remote control triple wacker looks fun to drive.
Glad you enjoyed it. I tend not to make long videos as most people get fed up after ten minutes or so, but I had little choice with this one as there was a lot to cover.
Yeah, thoroughly thawed out now thanks... and caught up on the sleep (long story but I only went to bed three hours before the alarm went off, so three hours in a 38 hour period !!)
I'll probably keep future updates short from now on. I'll try and find out what the plan is regarding the OHLE as that would be another big part of the project, but for now I'm guessing most of the work will be in completing the track work and building the station infrastructure before the OHL goes in.
The bearers at the joins need to be very well supported by ballast on both sides so the sub-base needs to be in good condition.Thanks, found a nice close-up picture on page 15 of http://www.track-maintenance-cost-o...nager-modular-track-renewals-network-rail.pdf
The tilting wagon concept for S&C delivery isn't new, just new to the UK
Otherwise this may happen: https://www.gov.uk/raib-reports/report-04-2018-freight-train-derailment-at-lewishamThe bearers at the joins need to be very well supported by ballast on both sides so the sub-base needs to be in good condition.
It occurred because the first of the two derailed wagons, which was probably carrying an uneven payload, encountered a significant track twist, resulting in there being insufficient wheel load at the leading left-hand wheel to prevent its flange climbing over the rail head.
The track twist had developed rapidly following the hand-back because:
- the support offered by the track bed to the concrete bearers was poor
- the inherent flexibility of the bearer ties located between the two running rails made one side of the track more susceptible to the poor track bed support than the other.
That wasn't the first mention in RAIB reports of that eitherOtherwise this may happen: https://www.gov.uk/raib-reports/report-04-2018-freight-train-derailment-at-lewisham
There are also lots of other things in the video that haven't been picked up on yet
Small update:
I drove passed Langley junction this morning and can report that the track is now connected to the switch
Lots of welding to do there.
How long before the first train be it test train or tamper to enter plat 5?
Thanks guys, it's good that it's coming along nicely now. Although in the image shared in post #458 the OHL structures seem very close to the track, is that the final position of the OHL structures or is it just the way it looks in the image?
Just the way it looks.
Ahh so a illusion then, thanks for explaining.
The other thing I wanted to ask was I know off peak the idea is that there will be 2tph north of Hertford but would that likely be increased in the peak to 3tph?
Would the infrastructure be capable of doing so bearing in mind freights do pass though.
Bridge and stairs will usually arrive prefabricated on the back of a lorry, as will the lift shaft components, I’d expect completing the lift machinery and testing operation would be the main time consuming aspect...The track in the platform was there last Friday evening (13th) when I used the bus to get to Hertford. What I did not see any sign of is the passenger access from the footbridge to the platform. Should would be concerned, or will this be something pre-fabricated that can appear over a few days?
I popped over to Langley junction to video the HST farewell tour on the last leg of its journey and was amazed to see nearly all the OH masts are up... presumably in readiness for the work that commences at midnight on Christmas eve
I'll see what I can do, but with Christmas in the way, I can't promise to capture everything that happens during the closure
It also looks like there’s a concrete slab in the gap between the tracks, perhaps there’s a trackside building to go there? Either that or it’s a redundant concrete slab that it it was easier to go round than remove...Track geometry is a bit counter-intuitive - something apparently minor can have a surprisingly big effect on where the track can go. In this case I think the track has to go far enough to the left to be a safe distance from the "old" OLE mast which is almost blocking the view of the EMU on that photo, and to bring it back to parallel with the Down Slow would have involved quite a tight curve. Since the land in question appears to be in railway ownership and there are no obvious major earthworks in that area, probably cheaper and easier just to let the track arc out rather than trying to bring it back closer or replacing the mast in question with another longer/wider portal. I assume the piling to the left of the photo was part of this scheme to create level ground for the new track, but that is to do with where the track goes near the turnout and would still be needed whatever course it took between there and the station.
