Suggestions for Dawlish avoiding route(s)
Rich McLean
6 Feb 2012
High tide at Dawlish was 2018, and 1V60 appears to have been the last XC train through at 1902. Met office forecast was winds from the south 30 mph average.
1V64 2045 off EXD (due to depart 2058) may still run down, decision still to be made
Tobbes
12 Aug 2012
If the LSWR was relaid could 70 - 90 mph be possible in several sections?
If I read the NR options paper correctly, £875m (including 66% optimism bias) buys you a double track mainline all the way, new Meldon Viaduct and 100mphg running.
Sounds great!
(And in the grand scheme of things, not an enormous amount of money).
Rich McLean
6 Feb 2012
1V64 is running. Turns out XC Cancelled many services due to making sure sets end up in the right locations if the wall had to shut to traffic, plus delays to an earlier service. Remaining XC diagrams due to run to Plymouth as planned
21C101
19 Jul 2014
Sounds great!
The line to Okehampton is already 50mph. For a diversionary route, a single track with 75mph and a permanent speed restriction of 30mph over a refurbished Meldon Viaduct as well as loops at Okehampton and Tavistock would be enough to support an hourly service and I would think cost rather less than that. (but its discussed to death further up the thread so I won't say any more)
Ash Bridge
17 Mar 2014
Stockport
The Class 42/43 Warships could manage 80/90mph on the stretch from Sampford Courtenay through Bow and North Tawton before the line was closed as a through route.(Source:The Withered Arm, TWE Roche)
D1009
22 Feb 2012
Stoke Gifford
This rather shows that it is not just extreme events that shut the line. Plenty of people tonight would be quite happy to have a half hour longer journey while they go at 60mph via Okehampton while remaining on the same train.....
To be fair the line isn't shut, it's just that a certain type of train doesn't like seawater crashing over its roof.
6 Sep 2011
Blackpool south Shore
The damage from salt water corrosion to rolling stock must cost the railway a pretty penny over a period of time. Living in Cornwall it certainly caused severe corrosion to body work & components of many cars near the coast!
Rapidash
3 Sep 2013
Torbaydos, Devon
Huh, I got the bus back this evening without even knowing about high tide! My intutional magic powers!
I highly recommend getting a train along the wall in a storm. Best thrillride you can get as a commuter without being a theme park reviewer:)
Always a laugh when theres some newbies are on board, the screams can last for aaaaggggess. :p
DDB
11 Sep 2011
Dawlish being closed caused knock on effects up and down the country with stock being in the wrong place and not being able to get stuff back to the right depot for big exams. (I'm assuming trains can 'holiday' at the wrong depot for day to day stuff if the line is blocked for a couple of days.)
It only needs a low capacity diversionary route to be able to recover stock stuck on the wrong side and move sets between depots over night for deep maintenance. In this case it would probably have meant that XC would have kept running because they knew they would have been able to get their trains back for tomorrow whatever happened.
It would also allow the sleeper to keep running.
DBB
Xenophon PCDGS
17 Apr 2011
When the fire occurred on the Britannia Bridge in 1970, there must have been some motive power on Ynys Mon that was stranded there.
MarkyT
20 May 2012
Torbay
And without the (ironically resultant) modern road bridge, presumably any road haulage of stock over the old suspension bridge would have been impossible.
snowball
4 Mar 2013
According to this page, two class 24s, some coaching stock and some DMUs were stranded on Anglesey and operated a service. Maybe they were maintained at Holyhead?
I've read more detailed accounts in the past but have forgotten a lot of details and I'm not sure whether the info is online.
Ash Bridge
17 Mar 2014
Stockport
I think this stock was retained to operate the service, but there were other locomotives (class 40/47s)stranded. These were separated from there bogies and taken by sea from Holyhead to Barrow-in-Furness, and re-railed there.
MarkyT
20 May 2012
Torbay
I hadn't thought of that! Makes a lot of sense seeing as road haulage would have been impossible.
Basically the Voyagers are causing all sort sof problems.
Please tell me IEPs are supposed to be hardened against splashes of sea water?
Rich McLean
6 Feb 2012
Will only be 1 or 2 diagrams per day operated by IEP to Paignton and back, unless the add on order is taken for the West of England
21C101
19 Jul 2014
XC Voyagers banned down the sea wall until after 1000hrs this morning
So its not just a 1 in 30 year event its a semi frequent low level disruption. Probably worse than before as no one will want to take the risk of the wall falling down with a train on it.
And presumably when the IC125s are retired the replacement stock will have the same difficulties as the voyagers, so the line will close whenever the sea gets a bit rough?
Rich McLean
6 Feb 2012
I wonder what 455Driver thinks, with him being a driver that is new to the area, and by now (or shortly) sign the road along the wall?
Rich McLean
6 Feb 2012
Will IEP not be going to Plymouth and Penzance ? They will have to pass through Dawlish also.
At the moment its still going to be HSTs to Plymouth and Cornwall, and some paigntons will still be HSTs, but a Paignton diagram during the day at least will be IEP, so will have to pass the wall.
If the extension is taken to order more IEP for West of England services, then yes, everything London - WoE will be IEP,
HowardGWR
30 Jan 2013
It's as straight as a die all along that stretch. I cannot see any reason why it could not be engineered for a very high speed indeed.
Ash Bridge
17 Mar 2014
Stockport
Yes absolutely, and just to quote some additional information from the same source, the Class 42 operating the final Plymouth-Brighton through service in 1967 ran non stop Okehampton-St Davids in 28 mins. So what could more modern traction achieve on a modern alignment?
LateThanNever
18 Jul 2013
I thought it was actually authorised for 125mph not so long ago? Presume now the track has deteriorated.
Busaholic
7 Jun 2014
Yes,yes and yes. Never thought I'd become a 'yes' man but in this case....
Sea over the wall again at Penzance tonight, when it's a lot less rough than last night. When we get it, Dawlish often gets it about 1 to 2 hours later.
LateThanNever
18 Jul 2013
Does the Penzance 'washover' impair the operation of the station signalling? Which could be all the more fun when it is run from Didcot?
plymothian
26 Sep 2010
Plymouth
It was wet.
Basically.
Mainly wave and associated debris that caused problems - for train electrics and track. Dawlish station had flooded on the up line up to the railhead at one point, however Level 1 working was in operation on the down until around 10.00 with pilotmen assisting the driver on the down under a 30mph speed limit.
XC 1C11 made it through with a 40 min delay, the decision was taken to cut back the service to EXD until conditions had improved and any pathing delays could be kept to a minimum.
LateThanNever
18 Jul 2013
It was wet.
Basically.
So a really rigorous, reliable train service for Plymouth then?;)
