SWR Class 458 to be retained
For instance, Southern could decide that they need 28x 4 car EMUs to replace the glut in capacity left after the 455 & 313 withdrawl. They may seek a 10 year lease, in which case, Porterbrook may seek agreeable terms to terminate on.
A ”glut” is actually an excess though. Although that doesn’t really make sense as you‘ve written it, it‘s definitely a short term way of dealing with a shortage of capacity in any of the 3 DC areas.
…although that was before we were correctly reminded they aren’t DOO compatible.
swr444
26 Aug 2008
Well, there could be many what-if reasons, to be fair.
There could be a new build fleet strategy, perhaps a fleet swap strategy. There's been all sorts of goings on in the past.
In simple terms, as things stand - yes, there's no reason for Porterbrook to change anything, but there's plenty of variables which could very quickly change that.
I do entirely agree here - all else withstanding, the situation as described by others upthread just seems downright insane - but I suppose that isn't unheard of in the industry of late.
They are not DOO compatible and have 0 cab space to fit in monitors, so they’re no use to southern
GWVillager
2 May 2022
Wales & Western
Then SWR should keep the trains that are just being refurbished for them and leave Southern some 450s - or even 701s for Bombardier/Alstom commonality. (No anger directed at you, of course!).
Again, I struggle to see a situation where the 458s don’t end up with SWR.
Doomotron
25 Jun 2018
Kent
Perhaps you could offer your services as an auditor for the next survey. ;)
It's off topic, but the way I'd do it (and I have no idea how the calculations would actually work :lol:) is to count it by units rather than coaches and then to combine that with the amount of services an average unit of a class would run, therefore making it more understandable from a practical point of view for passengers. Therefore if an operator had (for example) one ten-coach set of fourty year old coaches that only did one train per hour and twenty four-coach trains that are twenty years old that did six services per hour, the average age would mean closer to the lower end as statistically you're more likely to be going on one of the twenty year old trains. Obviously it isn't perfect, but neither is the calculation they currently use, which is a bit misleading to passengers I think.
Goldfish62
14 Feb 2010
Can't argue with that methodology.
Juniper Driver
17 Jul 2007
SWR Metals
The cost of training crews on 458/4s and refurbishing the cabs sit entirely with SWR (DfT), that’s not a small amount of money as you’re looking at at least half of the drivers at Fratton and Bournemouth, and probably 3/4 of guards at both depots. We all know that currently trying to get money out of the DfT/treasury is like trying to get blood out of a stone. I can’t see the funds being released and the TOC will be made to take the fall.
Has much changed then? I don't remember much about the first conversion but was it a day (as I already knew the 4 cars).I can't remember.
They had to reconfigure the TMS, but that probably didn't affect it too much.
pompeyfan
24 Jan 2012
Very few Fratton or Bournemouth crew will have knowledge of them so it’ll be a conversion course from Desiro stock which I imagine would be a full week
driverd
29 Mar 2021
Thanks for clarifying - I suppose a chasm in capacity. Or a glut in undercapacity.
I was just giving that as an example of how situations can change - not as any form of speculation etc.
In all fairness, though, given that 442s were seriously suggested as a future fleet for TPE (notably lacking, amongst other things, diesel engines or compatibility with AAR equipped locomotives and being DOO), I hardly think lack of screens would be a showstopper if such a move was desired. Cab re-designs have been done many times around the network (ie: Northerns 170s which are being fitted with blanking plates over the prospective location for DOO screens - was previously a clipboard/light proving/basic TCMS or fault lights depending on unit and has since been all rearranged or in the case of the diagnostics/TCMS screen, completely removed).
Big Jumby 74
12 Feb 2022
It was a refresher for most IIRC, although there were a small number who were due to work them on the inner sub who did need to learn them from new.
Juniper Driver
17 Jul 2007
SWR Metals
That's a good point.Wonder if I will still drive them.
Yup it was a refresher.
One of the drivers I know before he retired threw the new 458 book in the bin…(He didn't learn the original 4 car units) Which I retrieved and was quite surprised with the amount of content in it.I never got one of these books and I haven't got the original either…if there was one.
Peter Sarf
Croydon
If they are enough of a training issue for SWR (moving to a route they have not worked before) then Southern also won't be interested.
Irony is that if the 458s were considered for replacing 455s then keeping the 458s as 5-car units might have been more sensible for the 10-car routes in greater London.
GWVillager
2 May 2022
Wales & Western
lxfe_mxtterz
3 Mar 2018
Sarahdale (West of Emmerdale)
The panelling also looks as if it's new, though I'm not sure. Still doesn't look cosy, exactly.
Looking at the interior pictures, it appears that the interior panelling has been left untouched, with the fittings below the windows still in that gaudy blue colour. They have fitted internal doors between standard and first class though. Agreed it doesn't look particularly cosy.
Invincible
23 Apr 2022
A Twitterer has sent a photo of them in which the seats are (just) visible, and it looks to me like they have been replaced, with FISA LEAN (at least it looks like those) in both classes:
(Link is to a photo of a unit with seats visible, just)
So other than new seats, first class back to what it was?
the tweet also includes
"Our 458/4s 417 and 407 will be going out on an overnight test run tonight working the following; 5Q80 2232 XBM- SOU via BSK 5Q81 0226 SOU- WIN via BSK 5Q82 0357 WIN- XBM via BSK"
and in a later tweets
"5Q82 arrived into us at 0559 after the first night of 100mph testing and all seems good! Driver reports they comfortably do 100mph."
"Trust me the refubs been done well! They’re lovely units now"
TEW
16 May 2008
Yes, the interior panelling looks unchanged in photos I've seen.
DelW
15 Jan 2015
... which makes it even more unfortunate that their apparent fate will be to sit rusting on storage sidings for four years and then be scrapped.
While we taxpayers who have paid for the leases for that period (and indirectly for the refurb) won't ever be able to travel on them, and will continue to suffer short forms, overcrowding, and unsuitable stock on long distance services.
It's a ludicrous situation, though of course it's happened at least twice before in recent history, and in the same area too.
Juniper Driver
17 Jul 2007
SWR Metals
Great news.
adc82140
10 May 2008
Of course no matter what gets decided (or not) by DfT now about any units future is not the final answer. There is a general election due in the next 12 months, and more likely than not we will have a change of government. Even if the current lot decide to stick the 458s in sidings, that could change next year.
Doomotron
25 Jun 2018
Kent
I doubt the future of a small fleet in the south west has any relevance to the government no matter who is in charge. Far larger projects have not had their fate changed by changes of government. Conservative or Labour, the next government won't have an effect on the 458s - whatever fate they have now is almost certainly the same one they'll have after the election, whether it's to keep them or bin them.
GWVillager
2 May 2022
Wales & Western
It’s more than possible. If Labour puts control of the railways in the hands of a new, dedicated organisation (as seems likely), the 458s will almost certainly find themselves in service within a few years. And then there’s also the question of pre-general election. If the Government can make a big show of it, the 458s might be an easy way to appear as if they’re investing in rail, especially in key seats.
DelW
15 Jan 2015
Well, these units were supposed to be used to improve services running through Jeremy Hunt's constituency - which he's allegedly considering not contesting, as boundary changes make it more marginal than previously. Maybe he'll suddenly find some money down the side of no11's sofa to put them to work?
GWVillager
2 May 2022
Wales & Western
That’s my speculation. But it’s not for this thread I suppose!
30 Jul 2015
It looks like 458428 is planned to be delivered from Widnes on Tuesday.
5Z53 0805 Leicester L.I.P. to Widnes Transport Tech
5Q53 1432 Widnes Transport Tech to Wembley Receptions 1-7
No onward paths are currently shown on RTT, but I am guessing it will be heading to Bournemouth in exchange for 458524?
HamworthyGoods
15 Jan 2019
The railways already are under control of a dedicated organisation - the DfT.
