A Dft requirement I believe
More than likely someone high up in SWR or DfT lives there.
I’m led to believe the 1800 off Waterloo used to be first stop Haslemere for exactly the same reason, although it could well be Railway rumour.
There are 3 fast Portsmouth to Waterloo services introduced in each direction on Sunday afternoons/evenings:
http://www.realtimetrains.co.uk/train/W30389/2019/05/19/advanced
http://www.realtimetrains.co.uk/train/W30390/2019/05/19/advanced
Calling Waterloo, Clapham Junction, Guildford, Havant, Fratton and Portsmouth & Southsea. Waterloo to Portsmouth taking around 90 minutes.
And here’s the Bournemouth Line 442 Sunday up working
http://www.realtimetrains.co.uk/train/W39359/2019/05/19/advanced
Interesting calling pattern and odd choice to run via Cobham, mixture of a headline train and route retention. Can’t help but think via woking would cut off a couple more minutes.
Running via Cobham avoids the flat junction at Woking. I would not be at all surprised if this is why. Remember way back when the Portsmouth line was first electrified, it was the Cobham line, not the line via Woking, which got the third rail, and was therefore seen as the main line to Portsmouth for a while! (This is why the Southern Railway never got around to grade separating Woking Jn).Interesting calling pattern and odd choice to run via Cobham, mixture of a headline train and route retention. Can’t help but think via woking would cut off a couple more minutes.
!!! I'm absolutely thrilled with that last change as I commute from Basingstoke around that time.
However, I AM curious about its likely formation. It's currently a single 444. Do we know what's likely to happen to it?
Besides that I'm curious as to where the released 159s will go. I've noticed that the WoEs drop off in length sooner in the morning shoulder peak and earlier in the evening too than most other services. Do the logistics work for strengthening, say, the 0829 from BSK (currently 6 coaches) and the 1850 from Waterloo (which IIRC is also 6 coaches)?
Thanks a lot, very helpful! Do you know what's happening with the released 159s off the Hampshire peak extras? I imagine it would make sense with the fleet ageing and starting to drop in reliability to keep them as maintenance spares. Or is there something else planned for them?The morning train will be planned 10-444 running just in front of the 6-159
Honiton as a relief.
In the evening the new 18.48 Waterloo to Poole acts as a relief to the 18.50 West of England.
Hopefully that 18:48 Poole won't be 450s as some folk will decide to travel on the diesels for a better trip (2+2 instead of 3+2 seating)
A couple of the down WofE trains in the evening, 1850 and 1950,will be made pick up only at Woking, which should theoretically move people onto the additional 1848 and 1948 to Poole.Hopefully that 18:48 Poole won't be 450s as some folk will decide to travel on the diesels for a better trip (2+2 instead of 3+2 seating)
Is this a confirmed passenger service? I see in the RTT link that while it shows as a class 1 it also says doo....
Will it run year round?
Certainly could be useful in summer and it's a reasonable timing for weekenders going back.
A 17:05 Reading will be very well received, since the 16:50/17:20 departures are usually full & standing by Clapham. (Although it probably doesn't help that these services are worked by 450's)
It is a passenger service, it’s at this time of the timetable process data issues such as that (which would be DOO if it was ECS) are resolved.
The train is specifically aimed for weekenders returning home.
5-444I hope that 19:48 isn't a 442... All stops bar Redbridge from Basingstoke. If the Brighton line is anything to go by, keep the 442s well away from stopping work!
That's a relief (if you'll pardon the pun). Glad to see reliefs getting used again.5-444
Should take a considerable number of Basingstoke passengers off the 3 car 19:50 Salisbury.That's a relief (if you'll pardon the pun). Glad to see reliefs getting used again.
However, I've noticed the 19:48 skips Woking so I can't see it helping much in that respect.
Hadn't considered that, fair enough.Should take a considerable number of Basingstoke passengers off the 3 car 19:50 Salisbury.
You're entirely correct, I've re-read the email and there's only one through Windsor each way, the other two I was thinking of run empty to Hounslow then in service to Waterloo.
1R92: http://www.realtimetrains.co.uk/train/W30439/2019/06/20/advanced
1R94: http://www.realtimetrains.co.uk/train/W30440/2019/06/20/advanced
the two Windsors are:
1U90 up: http://www.realtimetrains.co.uk/train/W30445/2019/06/20/advanced
1U91 down: http://www.realtimetrains.co.uk/train/W30446/2019/06/20/advanced
I suppose it could have been given a 1Bxx headcode, but then it was decided a good while ago they were going to be K's as NR weren't happy to allow down trains to continue using E's, as with the Netley road stoppers.
Sorry to go back two pages but after rereading the thread I’ve just noticed the above. Is there any reason why NR didn’t want them running as E’s? Considering there’s 2 lots of 2R’s and 2S’s it seems odd to start pulling rank. Is there any news on when the new hourly semi fast Netley services will being running and what head codes they will likely use?
Looking at RTT, it seems it may well be a case of getting it out of the way, as there's a standard Windsor only 4 minutes behind it at Staines.Interesting - the 1U91 that you have posted seems to be calling at only Feltham and Staines before ending at Windsor. I'm sure it will be welcomed by some, but I am disappointed as its not stopping in Ashford, which is usually served by all Windsor trains...
Although the current 1705 covers the same route to Ascot. The gain is really the extra Aldershot train at 1654, though Reading having a regular interval 4tph service from 1550 to 1950 is also a benefit.A 17:05 Reading will be very well received, since the 16:50/17:20 departures are usually full & standing by Clapham. (Although it probably doesn't help that these services are worked by 450's)
