glynn80
- Joined
- 1 Jun 2008
- Messages
- 1,666
*Regrets ever opening his mouth*
I thought I'd made it clear in my original posting. Let me explain it again...
The changes will benefit me as I get less restrictions and more flexible return options on an Anytime Return ticket for the same price as the current Standard Day Return ticket for Wigan-Lancaster
If you think I'm going to be worse off then so be it.
But you must accept that not everyone is going to be worse off with these changes, and I for one am not convinced that I am going to be worse off come next week than I am now. Not everyone uses/eligible to use a railcard you know, and neither do they all necessarily travel during the peak period, and you seem to be peddling the same arguments all the time based on scenarios that only a percentage of rail users will be directly affected by.
Nothing personal mate, just explaining the situation how I see it.
The following should illustrate the point being made by myself and also show alex57601 what were are saying.
All of the these fares are ignoring the minimum fare as alex57601 said he didn't travel at peak times so won't be affected by these.
The railcard fares before were as follows-
Standard Day Return £8.25
(valid at anytime for travel with outward and return portion on same day)
Saver Return £8.90
(valid at anytime for travel- outward portion valid for one day, return portion valid for one calendar month)
The fares after are like this:
Anytime Day Return £8.25
Anytime Return £8.90
You stated the following
"The changes will benefit me as I get less restrictions and more flexible return options on an Anytime Return ticket for the same price as the current Standard Day Return ticket for Wigan-Lancaster"
How are you getting less restrictions, the Saver was never restricted on this route? Also how do you get more flexible return options, you could of always purchased a Saver Return which would of been valid for return travel within a month so why did you never purchase this ticket instead of the Standard Day Return and finally the Anytime Return is certainly not the same price as the old Standard Day Return, it is the same price as the old Saver Return.
Also noone is saying everyone is being affected, people are saying that 16-25 Railcard holders are affected end of story, even though its a small percentage the publicity states there will be no fare rises.
Personally I think you need to accept you are trying to argue points with which you have done no research and you have no expertise in
