Ste I'm in total agreement with you!
I find that part of the article rather funny, as I actually pointed the Wigan-Lancaster return fare out to Yorkie a few weeks ago both before and after the change. As I start at Lancaster University later this month (and will be doing some travelling home occasionally) I explained to Yorkie, albeit to little avail, that the changes actually benefit me on this journey as not only does the fare stay the same, it is less restrictive in the sense that it allows me to go home and stop overnight and return at any time within one calendar month without having to shell out for two singles separately or be bogged down in peak-time travel restrictions, as per currently.
That is not correct. How is it less restrictive? You were able to return at any time within one calendar month before; you are still able to. That is unchanged. You were not "bogged down in peak-time travel restrictions" before, the ticket was unrestricted; but in total conflict with what you just said, you ARE now "bogged down in peak-time travel restrictions" as the discounted fare is not valid before 10:00!.
The £8.90 fare is how much it will cost when bought with a 16-25 Railcard.
Correct.
And the last time I checked you currently can NOT use a railcard between 7am-10am (aka peak-time), and you won't be able to do so anyway after the change...
Incorrect! You can use your railcard at any time, subject to minimum fare restrictions. That means that, for this journey, you could use your railcard before 10am before but you can't now.
and I for one don't intend to buy the ticket in the peak-time anyway.
Then it doesn't affect you personally, but it does affect others.
Even if you go with the standard fare without a railcard discount there will be no restrictions when you can travel for both the outward and return legs, and there will be no change to the times when you can travel on a standard ticket after the change.
Correct. there is no change for non-railcard holders.
I will also like to point out that the fare is set by Virgin Trains, and not Northern.
Can you please tell me where you get that information from?
You will also find that there are very little services run by Northern that run direct between Wigan and Lancaster anyway.
Correct, but that doesn't affect anything.
Therefore it's a load of bull$hit about the Wigan-Lancaster return fare jumping up by 52% come next week.
No it is not "bull$hit". For 16-25 card holders travelling before 10am it IS going up by 52%.
In fact, the changes are great for me as the ticket will be upgraded from the current Day Return ticket to the Anytime ticket at no extra cost whatsoever and with no changes whatsoever.
No, that is
not what is happening. The Saver ticket is becoming Anytime. Standard Day becomes Anytime Day.
Furthermore I'm beginning to think now that some of these claims that fares are getting more expensive all-round are greatly exaggerated,
They are not exaggerated. They only apply to 16-25 holders at peak time. That has been made clear.
and I can see serious flaws in these claims as it is only a handful of operators that are spotlighted and some of the figures are meddled with by omitting what the type of fare is to try and suit the argument.
Only 3 operators are affected, 1 has promised to fix it. No claims have been made that it affects any other operators. No figures have been meddled with (that's slander!), and the type of fare is, in ALL affected cases, Saver to Anytime.
I suggest that everyone should do a check on National Rail to see what their fares are like now on the journeys they make and compare them with what they will be like after the change,
I suggest using Evolvi.
don't forget to get quotes for journeys with and without a railcard. Draw your own conclusions from that whether the fares are going up and whether your ticket becomes less flexible, as Yorkie and the article claims to be happening.
To quote a common phrase: "Don't believe everything you read in the newspapers."
Yes, but this time the paper has got the story correct.
Well if Virgin are setting that fare, and things seem to have improved, then surely most of Virgin's fares are going to be in a similar position...
Virgin do not set that fare - where are you getting that information from?
No, Virgin's fares are not in a similar position.
Merseyrail/Northern are doing nothing in respect of fare rises, they are remaining the same until January 2009.
They are causing increases for 16-25 holders travelling at peak time. Nothing more; nothing less.
I also find it hard to believe that FGW suddenly stopped implementing a fare increase simply because a newspaper spoke to them...
It will be interesting to see what happens.
The only thing that affects me is that I could have used a saver during peak time on Virgin because I have a railcard, and apparantly I can no longer do that.
That is correct, this is because the Saver had a MIN fare of £8 before 10am. You can no longer get this fare before 10am due to the ticket now being re-categorised Anytime therefore the MIN fare is £16 which is higher than the ticket cost, hence no discount. You are absolutely correct on this point.
However, I am sure that Virgin will ammend this, to allow the use of off-peak tickets on peak trains with a railcard. Charity workers get this benefit as well, so are Virgin really going to upset them?
Virgin do accept Off Peak tickets on any train with a railcard, that is correct. However that does not help with Wigan-Lancaster as there is no Off Peak ticket available.
ATW, Merseyrail & Northern set fares remain unchanged. I am sure that some fares on other operators may increase, but not neseccarily because of simplification. I am yet to see a convincing example of major fare increases by stealth.
LM have done 6% increases by stealth for non-railcard holders travelling at peak time, the gap will probably widen to a higher level than 6% as the new Anytime fares are not regulated.
I would just like to further ask the question in relation to Ste's original post...what restrictions are there on an Anytime ticket that are not on a Saver ticket apart from the Railcard restrictions?
None - just MIN fare restrictions for railcard holders, that is correct.
Rather one-sided though as to be unbiased you'd think it would mention the savings railcard holders are now making on AP tickets. Something positive, oh no, you can't say that....
It is positive but that happened back in May. Also Advance tickets are generally not available for the people who are affected by this particular change.
