The impact of tilt on keeping a train on the track or do you need tilt to go around a corner faster?
Ken H
11 Nov 2018
N Yorks
That is also my understanding.
I *think* the BR APT-P electric power cars (in the middle of the train, non-passenger carrying) didn't tilt either, as there is no benefit and it complicates keeping the pantograph in the correct position relative to the OHLE.
no, they tilted. they had a linkage between the bogies and the pantograph so the vehicle tilted but the pantograph didnt.
Ken H
11 Nov 2018
N Yorks
I've always had a niggling doubt about that - the reduced body profile surely means it stays within the "standard" profile at any tilt angle? Although APT had a transponder system I think it was for speed supervision not to turn tilt on and off.
Pendolino has less reduction of profile, but also less tilt angle, so the same may or may not apply.
Incidentally the APT, at least in its initial configuration where it tried to zero out the lateral acceleration, would tilt the "wrong" way if it was going round a canted curve at below the equilibrium speed.
APT had sensors in each vehicle that fed to the next vehicle to manage the tilt because of a lag between sensing cat deficiency and the kit tilting the coach. the leading vehicle didnt have the feed to the ride would have been more exciting!
I seem to remember that a wrong side failure of tilt (like you mention) was one of the problems the APT systems had to resolve. A wrong side tilt failure would take the APT out of gauge.
It wouldn’t. Fully tilted either way it must be in gauge.
They do it with cant deficiency
cant is the amount the outer rail is higher than the inner rail on a curve measured in degrees.
Passengers in a train going round the curve at the right speed will feel no lateral acceleration
If you go a little faster, the passengers will start to feel lateral acceleration. you could measure that with a plumb line and measure the angle between the uprights in the coach and the pendulum. or use an accelerometer.
That angle is cant deficiency. the amount the track isn't canted to cope with the curve at that speed.
You can remove that cant deficiency by tilting. The APT ran into trouble as passengers felt sick when their perception of up differed from what they saw outside.
You cant tilt too much because of slow trains (esp freight) that cant cope with large amounts of cant.
I think the original rule for cant deficiency was 8 degrees. But when the LM wanted to do 110mph trains they started to use 'relaxed curving rules' and 9 degrees.
The ER had a different tactic, got out bulldozers and straightened out curves.
Cant (or superelevation) is the amount the track is elevated on the high rail. For a given curve radius, and a given amount of cant, there will be a balancing speed where a passenger would feel no lateral acceleration. The equilibrium cant (E) is 11.82 x the square of the speed (in km/h) / the curve radius in metres.
Maximum cant applied (in this country) is 150mm, roughly six inches, which by coincidence is also roughly 6 degrees. Exceptionally you can go to 180mm.
Cant deficiency is the theoretical amount of additional cant that would need to be applied to achieve an equilibrium for a given speed. It is usual practice to have less cant deficiency than cant; I was taught that good practice was 2/3 cant 1/3 deficiency, but it’s a lot more complicated than that. You can go up to 50:50.
However there are also maximum levels of cant deficiency, this is 110mm (4.5inches), exceptionally 150mm (6 inches). This is what the passenger experiences as lateral force; if you go round a curve with 150mm deficiency you will know it. I referred earlier to research in BR days that enabled the exceptional values to be used.
For tilting trains, maximum cant deficiency is 265mm. The difference between that and the normal cant deficiency values is compensated for by the tilt system.
All the above apply to CWR only - there’s lower values for jointed tracks, and there are variations for short radius curves and other factors.
Exactly the same in the Pendolinos.
Unlike tilt, cant does reduce the overturning risk because the horizontal position of the centre of gravity, on the centreline of the train, is moved towards the inner rail.
If I recall correctly the maximum lateral acceleration due to cant deficiency is around 0.65m/s2 or 6.5%g. If the centre of gravity is 2m up then you'd have to be pulling about 30%g lateral acceleration (on standard gauge track) to risk overturning. Narrow gauge is more prone to overturning unless the centre of gravity is lower in proportion to the difference in gauge.
However, because tilting trains run faster round curves, the margin of safety against overturning is reduced, so there are specific extra standards relating to crosswinds. If non-tilting trains were allowed to run at those speeds then they would also have the same overturning risk.
And just to complicate things further, there is another mode of derailment on curves which is when the outer flange climbs up the rail, so the train carries on at a tangent but doesn't overturn. Which happens first in an overspeed depends on various factors.
ac6000cw
10 May 2014
Cambridge, UK
Thank you, I stand corrected :)
I think things like fast, curvaceous, roller-coaster rides illustrate the effect of cant nicely. With very high levels of cant in the sharp lateral curves, the cant has the effect of translating of most of the centripetal force (which is making the vehicles follow a curved path) into a force perpendicular to the track, which you can feel pressing you down harder into the seat when the 'train' is on the inside of a curve.
More extreme examples are the motorcycle 'Wall of Death' displays, where someone rides a motorcycle around the inside of a large vertical cylinder i.e. 90 degrees of cant (the bike is almost horizontal, with a small amount of upward lean to counteract the force of gravity, and the centripetal force to make the bike follow a circular path is provided by the wall of the cylinder). The bike just needs to be going fast enough to generate sufficient centripetal force to keep it pressed hard against the wall (so the tyres can grip and stop it sliding down the wall due to gravity).
Taunton
1 Aug 2013
As I understand it, the purpose of the tilt is passenger comfort. Stability on the track is secondary.
The NR specification for tilting stock is the speed/stability must be fully safe, not only if the tilt has failed, but if it has reacted incorrectly and given full opposite direction tilt around a curve (eg it gives full left tilt at the start of a reverse curve, but then jams there). Uncomfortable, yes, and probably breaks some of the china in the buffet, but not unsafe stability. It also needs to still stay within the loading gauge if it has full opposite tilt.
It was, uncomfortable, yes! It didn’t break any china in my coach, but there was coffee everywhere and quite a few things on the floor.
stj
15 Apr 2019
How much would timings suffer if 125mph non-tilt trains were used on the WCML,after all the APT was designed for higher speed.Could the track cant be altered?Do we really need tilt?
Ken H
11 Nov 2018
N Yorks
There was a planning blight with APT. Tilt was going to solve the bendy WCML. meanwhile the western and Eastern regions were using bulldozers to remove speed restriction and allow long stretches of 125 running with no tilt. And making useful journey time reductions each year. The WCML needs to catch up.
Railperf
30 Oct 2017
Taking Glasgow to Carlisle as an example..the fastest recorded tilt timings of just under 65 minutes compare quite favourably with the fastest recorded non-tilt timings of 67 mins.
andythebrave
8 Oct 2009
In the Marston Vale
Carlisle to Glasgow April 1985 67m36s including a lengthy trs between Carstairs and Motherwell. 87002 in charge of 7 Mk3s on the down Royal Scot. Probably best not to repeat the speeds throughout; let's just say the ride was lively. Upon querying the significant overspeeds on arrival I was told that the wheels had just been retyred. Somewhat sceptical about that as no overspeed beyond 2% had occurred south of Carlisle.
Railperf
30 Oct 2017
I did not see that run in the Railway Performance Society archives. Do you have much detail of the run that you can DM?
andythebrave
8 Oct 2009
In the Marston Vale
Regrettably, I mislaid the substantial logbook that contained it. I have a reasonably good long term memory (it's short term that I struggle with).
Gretna Jc 06-46 Lockerbie 16-45 Carstairs 43-35 Motherwell 55-47 Glasgow Central 67-36. Scheduled dep Carlisle 1331 arrival Glasgow 1450, actual departure Carlisle 1336.. arrival Glasgow 1443..
Max speed enroute 119 including 106 (!) through Carstairs. The trs was to 40 somewhere between Carstairs and Motherwell, otherwise completely clear. I recall the date as 1st April 1985 (but not an April fool!). Best I can do I'm afraid.
When virgin had the xc franchise did the 221 voyager trains use tilt
Yes, on sections between Stafford and Carstairs and between Leamington and Oxford. XC don't run the former any longer and the time saving with tilt between Leamington and Oxford (and if there was any on Stafford-Birmingham or Carstairs-Glasgow) was tiny, so they decided it wasn't worth keeping the tilt equipment working on their 221s.
In reverse order...
Yes we need tilt
No the track can’t be altered, at least not without very expensive land take
Timings would suffer, quite a bit, as described above.
Both the GW and ECML had the benefit of long straight sections. The WCML never had this. Eastern Region ‘got the bulldozers out’ to remove particular restrictions, but for a variety of reasons this wasn’t on option not he WCML.
krus_aragon
10 Jun 2009
North Wales
Alternatively: "getting the bulldozers out" for the WCML would mean rebuilding or replacing most of the line (i.e. what HS2 is doing).
a_c_skinner
21 Jun 2013
How much? My recollection of the introduction of tilt is poor (my wife made me live in the East for the intrduction of Pendolinos and has now moved me back West for the 80x changes) but wasn't a lot of the journey time improvement from changes in stopping pattern? No one is thinking tilt makes no odds, but a lot of us are wondering if it makes as much odds as we think. I ask out of genuine interest, not cussedness.
hexagon789
2 Sep 2016
The fastest post-tilt Euston-Glasgow was 4h08 iirc, the 1630 service calling only at Preston. The fastest pre-tilt (110mph max) timing I can find was the Royal Scot, 3 stops 4hrs 47 in 1992.
a_c_skinner
21 Jun 2013
Thank you. I think that means about half of the saving was due to omitting stops, doesn't it? Glasgow might not be the best example because the advantage of tilt is greatest on the southern WCML if I understand correctly. Back to my original thought that the gain of tilt once 140 mph was off the cards is modest and so (back on topic) extra trains will not have a huge case for tilt.
hexagon789
2 Sep 2016
A good proportion, yes.
Well there is this comparison of journey times, 110 non-tilt/125 with tilt/140 with tilt:
Birmingham 1h40/1h15/>1h15
Manchester 2h30/2h00/1h45
Liverpool 2h45/2h00/1h55
Glasgow 5h20/4h20/3h50
a_c_skinner
21 Jun 2013
Thanks. Those are different figures for Glasgow from your 4h47 and 4h08 and all this leaves the question of 125 non-tilt hanging in the air. Plainly that wouldnlt win back all of the time but it would win some. I still cannot see any more tilting trains being ordered for the UK.
I vividly remember that the proposed 140mph timing for Manchester was 1h52 with one stop. This was in the specification for the West Coast upgrade.
a_c_skinner
21 Jun 2013
Today is 2h11 with four stops, if I read things correctly, which must mean 140mph gained little. E&OE.
As far as I remember, the "Leamington-Oxford" tilt section was actually just a couple of miles in the Cherwell valley south of Aynho Jn, as a trial for the route.
Virgin XC also tilted with 221s on the Norton Bridge-Stoke-Macclesfield-Cheadle Hulme section, as do 390s.
Arriva XC abandoned tilt on that section, and the 22x have to stick to the PSRs with the associated time penalty.
North of Carstairs there is only one tiny EPS tilt section near Motherwell which is neither here nor there timewise.
On the XC route between Coventry and Stafford there are no speed limits which disfavour non-tilt stock over tilting stock.
