route:oxford
- Joined
- 1 Nov 2008
- Messages
- 4,949
The PPM has a fair proportion of it made in the UK hasn't it?
Oh found it on Wikipedia, looks like the mini-buses we have driving round the countryside.
It isn't a 'real' locomotive or multiple unit by my own definition
True it runs on rails, but so do trams.. Think I'ld call it a ' Rail mini-bus'
It seemed a shame that the Tornado boiler (for whatever reason) had to be fabricated overseas. You would have thought that someone in the UK could've made a boiler for a classic British locomotive.
In the last 30 years we've lost so many skills and experience, not just in railway engineering but mechanical engineering in general...
I think it is about time we started making more 'things', especially in advanced and skilled engineering.. instead of continuously importing just about anything and everything.
Railways and rolling stock can be the ideal place to start, imho.
. . . . .. Take for instance the Ford Focus, it is put together in Cologne in Germany but the diesel engine is built in Dagenham here in the UK. . . . . also happens with trains/locomotives . . . ..
Just wanterd to add a +1 to that sentiment.Yes indeed. Germanys export level is 3 times higher than UKs., just heard Vince Cable say that on Parliament Channel.
60s were as British as most of the other loco types. As far as DMUs go, 15Xs have American engines and German transmissions. Originally the Pacers had British engines and transmissions, but still German final drive. The 1st Generation DMUs were very British, even the British Vacume brake instead of American Westinghouse (a problem on pretty much everything else). EMUs and Electrics up to the 91 and 322 were quite British too, although the early ones (up to the 86 and some 319s) had French designed pantographs.
Was thinking about Buses, since I'm a bus person too. The last totally British bus would have been the Leyland Olympian, although later ones had ZF (German) gearboxes, and some had Cummins engines. Also brings up a surviving British design, the Leyland O.600 series engine, which was built under licence by both DAF and Scania until very recently (don't think they could quite reach the latest emissions standards) and dates back to the 50s, although has undergone various modifications since then (including bigger cylinder bore, turbocharging, and metrification). Apparently they still kept a distinct Leyland sound to them.
No, it was a Leyland 680, straight 6, 11.6l, 150hp. Same were fitted to many buses and lorries, both horizontal and vertical. Some had very similar AEC engines.
You're thinking of boxer engines, which were a German design but I'm not sure if they saw much use in Britain. Of cource the Diesel engine is German anyway, as is the Internal Combustion engine. At least we get the Steam Engine.
The bus is also a German invention, by Karl Benz...
