- Joined
- 15 Apr 2008
- Messages
- 15,964
Not quite, the fasts don't get moved over that far. The Up Slow doesn't move, it stays where it is now.
I'm perpetually perplexed by this board's policy of closing threads that go quiet for a while even if they relate to ongoing schemes.
One place where this scheme has received some discussion is here:
http://www.railforums.co.uk/showthread.php?t=109588
While I understand what you mean, it's worth noting that you can request old threads to be re-opened.
Three new junction names to learn:
Searchlight Jn (where the Down Stone leaves the Down Slow)
Yarnfield Jn (where the new route ties in with the old on the Stone route)
Little Bridgeford Jn (where the Up Stone joins the WCML Up Slow).
Searchlight Lane Jn, to be precise.
So if the plan is still to not have any timetable changes/increased number of services until Dec 2017, will the improvements at Easter and Christmas lead to a significant increase in reliablity/ability for slow running trains to make up time more easily?
Once a grade separated junction replaces a busy flat junction you will immediately get better reliability, as long as the new kit works properly.So if the plan is still to not have any timetable changes/increased number of services until Dec 2017, will the improvements at Easter and Christmas lead to a significant increase in reliablity/ability for slow running trains to make up time more easily?
Seriously -wow- IMHO Dec 2016 would be much fairer and reasonable - don't know if those are the right words.
Hendy delivery plan
p.72 here seems to suggest that the power supply upgrade will need to be completed before the timetable change.
Is the new flyover being controlled from the same workstation at Stoke SCC as previously, or is control moving down into Rugby ROC? (Seem to remember hearing that somewhere)
Has the weather over the weekend disrupted work or is it likely to still finish on time?
critical assumptions[/B] on external factors are being made:
National Grid END QUOTE
No bad weather in that part of the world unlike down South.
BBC Midlands News have done a feature about the opening today stating that the project has been completed on time and under budget.
When asked what the benefits will be, a Network Rail spokesman said: "It means faster trains, more reliable trains and more seats"
More seats??
The new railway removes one of the last major bottlenecks on the West Coast main line by allowing trains travelling to Manchester from the south and West Midlands to travel over, rather than across, the existing tracks.
This will help create the capacity for more frequent services through the Stafford area as well as speeding up journeys and improving reliability on the West Coast main line, one of the busiest rail routes in Europe.
The scheme is a £250m investment, part of Network Rail’s £40bn Railway Upgrade Plan, which has also seen new modern, more reliable signalling installed and improvements between Stafford and Crewe to allow trains to travel at faster speeds.
Work has taken place over the last four years and has been delivered on budget and 18 months early.
A key part of the upgrade is the new rail-over-rail flyover which means trains to Manchester, via Stoke-on-Trent, will now travel over the existing lines rather than having to slow down and criss-cross the tracks.
The first train over the new flyover, at Norton Bridge, was the 5.11am CrossCountry service from Manchester to Bournemouth.
