Things we don't see at stations these days
2 Nov 2019
Sandwich
Didnt they have suffixes too if they were pre-nationalisation? 4SUBs had them I think?
They did indeed and had a repeat letter after the numbers, for example a pre-nationalisation carriage would be numbered S12345S.
Taunton
1 Aug 2013
To be precise, it was if they were to a pre-nationalisation design. A lot of such stock was built under BR in the late 40s/into the 1950s, and this was of course what was left running in more recent times, including most of the EPB electric stock, which didn't even first appear until the early 1950s, but was on recycled Southern Railway frames, or new ones built to the old size.
Rescars
25 May 2021
In similar vein, all those fish-named departmental/pw wagons (salmon, sturgeon, seacow, dogfish, etc, with a shark brake van at the end of the rake).
32475
2 Nov 2019
Sandwich
Very true Taunton- thanks for verifying.
Meanwhile, another thing you don’t see now are finger boards on platforms denoting stops for the next trains. These were often kept in an upright timber case so that the appropriate boards could be selected by platform staff. I particularly remember at Haywards Heath there being a mix of older green boards with hand painted straw coloured lettering and the more modern black ones with printed white lettering.
As timetables changed from year to year, some destination stations on the boards were painted out and others crudely painted in.
Occasionally you’d see a board with chalked destinations for unusual trains such as specials. There were also red boards saying ‘Do not board this train’.
Falcon1200
14 Jun 2021
Neilston, East Renfrewshire
My dad remembers seeing someone trying to weigh a parcel on it but its weight wasn't within the machine's weight range so the recorded voice said "No weight", but this man wouldn't take no for an answer so he kept inserting another coin and saying "Of course there is weight".
Pity he didn't just think of weighing himself with and then without the parcel, so using only two coins!
Broad gauge track (in GW territory).
Or GWR style ATC (Automatic Train Control) ramps, although these lasted till a bit later than broad gauge track (early 1970s?)
Rescars
25 May 2021
Sutton had a sophisticated version, where frequently used boards were raised and lowered by levers into a magazine, a bit like a crude form of semaphore signal. There was also a case of boards showing the details for less regular workings.
nw1
9 Aug 2013
I remember the SR-design EPBs did indeed have this numbering ("S12345S").
At the time I assumed the second "S" meant "suburban".
Western Sunset
23 Dec 2014
Wimborne, Dorset
Water cranes
Barrow crossings
Ladies rooms
Porters rooms
All those little nooks and crannies.
Nowadays everything seems so grey, and bland, and cold, and concrete, and clinical, and unwelcoming...
Rescars
25 May 2021
More not heard than not seen, but, apart from an ever diminishing number of locations, those satisfying twings, clanks and clunks of semaphore signalling installations.
Taunton
1 Aug 2013
Lots more.
Regional colours. I was used to WR station signs being brown, and LMR ones dark red, but was amazed the first time I went over Standedge to find all the station signs were then suddenly bright orange.
Ken H
11 Nov 2018
N Yorks
Lots more.
Ticket machines were different. LMR ones were not the same as Eastern Region.
Roilshead
2 May 2017
Bomb damage, or bomb-blasted/burned-out carriages; Army/UDR patrols - NIR 1970s-80s.
peteb
30 Mar 2011
Unaccompanied dogs tied to lamp-posts before being secured on board a train in the guards van......!
AY1975
14 Dec 2016
Toilets at almost every station, including a lot of unstaffed halts.
And gents' toilets with no roof over the urinals so they were exposed to the elements - common at many rural stations back in the day.
And WC cubicles with coin operated locks where you had to insert 1d in pre-decimal days (hence the phrase "spending a penny"), 1p in the early days of decimalisation, then 2p, then 4p (2x2p), then 5p. These were mostly replaced by entrance turnstiles in toilets at major stations in the 1980s and '90s, while charging for toilets at smaller stations (that is, where the facilities were still in situ and open by then) was mostly phased out around that time.
In the last few years Network Rail has abolished toilet charges at all stations managed by NR itself. Some stations managed by the train operators (for example Glasgow Queen Street) do still have them, though.
Also, at least in the late 1990s and early 2000s some London Underground stations with toilets (not that many LU stations do have them) had the traditional WC cubicle coinboxes on the external door instead of on each cubicle door. I remember that at Osterley on the Piccadilly Line about 20 to 25 years ago, and I think you had to insert a 20p coin to get in. Not sure if any Tube station toilets still have that, though.
And in the 1980s and '90s at some London suburban stations, toilets for people of one sex only as discussed in this thread: https://www.railforums.co.uk/threads/trivia-stations-with-toilets-for-people-of-one-sex-only.241981/
ChiefPlanner
6 Sep 2011
Herts
Most staff offices not being secured akin to a Bank with keypads (never seemed to be a problem as "private" seemed to suffice)
Waiting rooms - sometimes with locally sourced fresh flowers (Hereford comes to mind) , others had time constrained gas or electric heaters!
D6130
12 Jan 2021
West Yorkshire/Tuscany
Racks of Edmonson card tickets and Bell Punch ticket date stamping machines in booking offices. (Other makes were also available).
Ken H
11 Nov 2018
N Yorks
Is that the same Bell Punch who made the Ultimate ticket machines used by many bus companies, notably muncipals?
The exile
31 Mar 2010
Somerset
Broad gauge track (in GW territory). Though plenty of the old rails can still be seen as fencing posts.
Spotted a fence post on Ffairfach that looked as if it must have been narrow gauge track - rail profile looked very small compared with what was laid next to the platform. Wasn’t going to jump down to measure it, though!
D6975
26 Nov 2009
Bristol
Trains.
There have been a fair few stations that have gone for long periods without any in recent times.
Bungle158
17 Jul 2019
Benaulim Goa
Guards waving green flags
For example, Iif a multiple unit fails and subsequently continues in passenger service but loco hauled, and if there is no electronic communication between guard and driver, a green flag will be used. Or at least was, l retired some years ago but used a flag in 2012 on a rescued HST service at Plymouth and up the line to Exeter
Deepgreen
12 Jun 2013
Gomshall, Surrey
This - collected tickets parcelled and sent to a head office, in this case thrown out of a guard's van onto the platform at Raynes Park in 1983.8326014894_e66622cf55_k.jpg
