I've discovered a ticket on BRfares with a really strange route. It involves going in the wrong direction, then changing trains and going back in the right direction, through your original station.
I won't give the real details, as it could be a loophole that some people are using, so here's an example using different stations.
It would be like a Newcastle to Glasgow ticket, routed via York. It would be slightly cheaper than a direct Newcastle to Glasgow ticket, and much cheaper than York to Glasgow.
When you use the National Rail website to search for Newcastle to Glasgow via York, it would offer you this ticket, and give you an itinerary that takes you to York, then back in the opposite direction through Newcastle to Glasgow.
There is no sensible alternative route making use of the via point, so I can see no logic to the ticket.
I've done a forum search and found this ticket was mentioned five years ago. It was suggested that the double back wouldn't be allowed, and you'd have to do the "York to Glasgow" part of the journey via the shortest route that doesn't go via Newcastle. If this is the case it opens up all sorts of possible journeys that would be cheaper than the 'proper' ticket.
How could a ticket like this come about, and if it's true you can't double back, why does the NR website say you can?
