Shaw S Hunter
TfGM may very well have aspirational plans for 2040 and beyond but in practice the most concrete idea they have publicised with regards to Metrolink in Salford is an extension from Salford Quays to a new street-level terminus at Salford Crescent station. Connecting Metrolink to the Atherton line would be rather difficult as there is no obvious location to do this and I am not aware of any suggestions on the matter. And there will also be the issue of 25kV OHLE between Crow Nest Jn and Wigan Station Jn to contend with. It might well be better for any further Metrolink trackage in Salford to be strictly street-running only and refocus planning of services on the Atherton line back to heavy-rail.
It's worth noting that pre-Covid passenger numbers had led to TfGM actively pursuing a 4tph service for the route but the combination of pathing difficulties in the Ordsall Lane Jn and Castlefield corridor area with the continuation of historical signal sections on the Atherton line made it impossible to path reliably. Fully modernised signalling along with restoration of the previous 70mph line speed would doubtless help a little but without grade separation at Ordsall Lane there is little additional capacity to be squeezed out of the area.
I suspect that the extra capacity, which would benefit all services in the area, would be best provided by a new tunnelled route across Manchester connecting the Pendleton and Longsight areas, effectively an updated Picc-Vic scheme which recognises the extent to which the Windsor Link has created demand for through services. But until the future of HS2/NPR is definitively settled there seems to be little point in discussing this idea in any detail. The most pragmatic way forward, as for many routes in the North, is to replace the increasingly tired Sprinter fleet, preferably with electrification but bi-modes will surely also be part of that solution. Network capacity issues are going to be expensive to solve but improving the on-board environment by replacing time-expired trains is a relatively easy win.
