Toilets on locomotives
HighlandSpot
29 Jan 2022
Edinburgh
Hello all,
I'm sure this isn't a typical inaugural post for a new member, but I'm fascinated with loco anatomies. Does anyone on here know where the toilet is located inside the cab of an old Class 42? I know on the Deltics they were placed in the nose compartment of cab no. 2, but what of the Warships? What other facilities did they have inside (wash basins, cookers...)? I've not had the pleasure of exploring inside one of them yet.
Also, if anyone knows the same about Class 25s, I'd be very interested in learning.
Thanks!
hexagon789
2 Sep 2016
Hello all,
Thanks!
Try the Barrowmore Model Railway Group website, they have a freely available selection of British Rail diagram books (plans of rolling stock essentially) and these will sometimes give a detailing of loco internal arrangements.
hexagon789
2 Sep 2016
Toilets on locos!
Never heard of that one, we certainly didn't have them on the Southern Region.
Whatever next?
Most of the 1950s/60s diesels and some electrics had just a urinal, but a few had a proper toilet and washbasin.
delt1c
4 Apr 2008
I did not know! Do you know if the warships had urinals or a proper toilet?
Believe that peaks had proper toilets in the engine compartment. Also most mainline locos had cookers in the cabs
hexagon789
2 Sep 2016
Wow, didn't know that.
Only ever on the footplate of 09's, 33 & 73's.
Oh and one 47.
47s had a urinal from memory, I doubt any shunting locos were equipped though.
The D800s I believe had a toilet at the No. 2 end; posher than Deltics which only had a urinal.
Though I the impression that like the heating boilers reliability of them was hit and miss.
Cowley
15 Apr 2016
Devon
I remember being fascinated by this subject as well after seeing a toilet on a loco diagram as a kid. I think it might have been a Peak.
32475
2 Nov 2019
Sandwich
This begs the question as to whether any class of loco had a urinal at the no 1 end and a wc at the no 2 end!
HighlandSpot
29 Jan 2022
Edinburgh
Here's a cutaway of a Deltic cab no. 2, toilet is in the nose compartment. Does anyone have a cutaway of a warship or class 25 they can post?
Cowley
15 Apr 2016
Devon
Looking at that I think I’d hang on until I got to a station!
hexagon789
2 Sep 2016
Interesting, I always thought the Deltucss only had a urinal. A toilet and washbasin is much more like the other long-distance earlier diesel classes.
david1212
9 Apr 2020
Midlands
I can't recall specifically but recall reading of issues found during preservation repairs / rebuilding caused by years of urine flow and it collecting in hollows / pockets. Also because the urinal was so inaccessible on the move alternative locations used ?
HighlandSpot
29 Jan 2022
Edinburgh
Did Class 25s have a urinal or toilet installed in their cabs? Also, does anyone have a link to a cutaway diagram of a warship?
Cowley
15 Apr 2016
Devon
Must admit that I’ve been looking and I can’t find anything.
Ashley Hill
8 Dec 2019
The West Country
Looking at that Deltic toilet were they flushable and where did the water supply come from. On a happy note being sat next to the traction motor blower you’d needn’t worry about any smells entering cab when exiting.
No sign of any having been any in ours.
Spartacus
25 Aug 2009
Given it's location I'm more concerned with where it went. In the wrong place I guess you could have made enemies of shunters very quickly!
Taunton
1 Aug 2013
The concept of having the facility in the nose originated in the USA. The very first GM FT units in the late 1930s had it in the main engine room, but the way the air intake was done before sealed air filters came along, when you applied full power the air pressure in the engine room dropped, particularly if the (manual) radiator shutters were closed, with unfortunate results on the toilet contents, and particularly on any user at that moment, so it was moved into spare space in the nose. British designers just followed on.
I believe a similar pressure differential issue afflicted some recent British passenger stock.
Ash Bridge
17 Mar 2014
Stockport
Not quite what the op asked for but the link below confirms that the North British class 41 Warships were certainly equipped with a full sized toilet in the engine room right alongside one of the power unit dynastarers! The class 42/43 Warships definitely had a food warmer as the 3rd from the end top row of switches (pictured) is labelled as such, although where it was located I do not know. Regarding toilet location on these I seriously doubt it was forward of the driving cab as the switches and further instruments continue all the way across to the second man’s position
Trackman
28 Feb 2013
Lewisham
Interesting, I always thought the Deltics only had a urinal. A toilet and washbasin is much more like the other long-distance earlier diesel classes.
I've seen them when I did a 'survey' on Deltics shortly after withdrawal.
They looked nothing like the cut-away picture above, in fact you it took you a couple of minutes to suss out what it was. It indeed had a wash basin just above. Could have been an urinal only, but I'm sure it had a seat. It was very compact.
I'm guessing the same as class 40's - Buckets.
