Toilets on locomotives
hexagon789
2 Sep 2016
Was it the Mark 4's, when going through tunnels?
I had an idea it was HSTs until the pipework was modified but there was a tunnel where the issue meant HSTs had a lower permitted speed through the tunnel than conventional trains. I'm sure this came up in an old thread, but I can't find it presently to refer to
Richard Scott
International Transport
Railtours & Preservation
13 Dec 2018
Believe that peaks had proper toilets in the engine compartment. Also most mainline locos had cookers in the cabs
Peaks had a urinal in the boiler room.
Pigeon
8 Apr 2015
I thought the loco had sprung a water leak until I realised what it was...
Peaks may have had a urinal in the boiler room, but this chap preferred the view of the lineside scenery approaching Ribblehead.
15 Jun 2018
It is over 45 years since I worked as a "secondman" at Stratford MPD, and I can't quite trust my memory these days...
Someone asked me about "restroom" facilities on the diesel locomotives, and I replied that there were none, we managed to answer calls of nature when we could.
I since wonder if I did actually see some sort of steel mini urinal facility on one or two mainline locos?
We had type 37, 31, and 47 as our mainline engines.
hexagon789
2 Sep 2016
On the contrary most first gen diesels and electrics had a urinal, some even had a proper toilet with folding washbasin.
15 Jun 2018
Gosh, how could I forget such things? Maybe we didn't drink as many enamel "billy cans" of tea as I remembered! :)
Big Jumby 74
12 Feb 2022
40's did, number 2 end, and Peaks had the full works just behind the Number 2 end cab, complete overhead flush tank. On the subject of Stratford, wonder if the 15/16's had anything - probably not enough room, and only designed for trip working anyway.
cadder toad
2 May 2015
37's had a urinal and I think 47's. I do not remember any curtains for privacy (who else would be there?). I used to do work underneath on shed (usually brakes) Anywhere near the urinal always stunk
Enthusiast
18 Mar 2019
The production Deltics originally had a toilet and washbasin in the nose at one end. They were removed when the air brake conversion was carried out.
david1212
9 Apr 2020
Midlands
While I can't recall where I have read about corrosion repairs required because of the outfall from the loco toilet, urinal or if not fitted a location used as a substitute.
lordbusiness
17 Dec 2014
I'm finding this thread fascinating and slightly horrifying at the same time.
Personally I think I would have held on unless in really desperate circumstances.
Thread drift- On slightly related note, I spent a significant part of my previous career flying as ALM on C130 Hercules military transports where the toilet facilities where similarly rudimentary- two urinals- one at each end of the freight bay and a chemical toilet (elsan) tucked inside the 'ducks tail' by the cargo ramp. We did get corrosion problems in the plumbing and occasionally a blockage in the urinal.
I spent a couple of years as one of the 'tac demo' (display) crews where the end of the display involved a Khe- Shanh style tac descent to land (2000ft approaching the threshold- nose over to land) for which the chemical toilet was always removed due to quite a lengthy period of negative g. On one particular display (Duxford) we nosed over and discovered that the rear urinal had blocked and the contents reappeared, floating in mid air before depositing themselves all over the ramp. Took some cleaning up before we could fly home.
I once spent virtually the whole of a 7 hour leg from Senegal sitting on the elsan after a dodgy local meal- should have declared myself unfit to fly but it would have meant delaying the whole flight and probably another 48 hours stuck there.
Don't ask me about arrangements on a CH47 Chinook!
MP33
19 Jun 2011
I went to an exhibition of various rolling stock at a station and a class 47 was available to look around. On the right hand side of the cab there was a electric ring for cooking. There was also a big red button, which when pressed rang a fire bell. What use that was I do not know as it had to be kept pressed to ring the bell. in a emergency no doubt you would leave the locomotive and not worry about the bell.
hexagon789
2 Sep 2016
I thought it was called the "Fire Alarm Test Button", ie for checking the fire alarm was working rather than sounding it!
43096
23 Nov 2015
On HST power cars the fire alarm test button, as well as the obvious of testing the fire bells, also stopped the local engine (using engines stop shut down both power cars). That worked fine until someone realised (in the MTU era when power cars caught fire more regularly...) that if you had a power car fire and pressed fire alarm test to shut down the engine it also inhibits the fire detection system for a short period, which would prevent the Inergen fire system activating, which is not what you'd want. So the fire alarm test button on the test was changed to local engine stop and a new fire alarm test button was provided on the cubicle.
