TPE Mark 5A coaching stock progress
driver9000
13 Jan 2008
Can those 68s still work other trains? Also, do they have full Mk5 controls in both cabs, or just one?
In theory yes although unlikely given the high availability required to TPE once the mk5A sets are in traffic although 68019 has been hauling freight recently as part of a return to traffic test after it failed in Velim. Both cabs have been fitted with the necessary equipment to work with the coaches.
SP Man
26 Aug 2018
Can you use both cabs as equipment in both. Normally planned for cab 2 against the stock and cab 1 leading.
EE Andy b1
12 Dec 2013
CLC
Why would it matter what end of the class 68 is next to the MK5As if both cabs are fully equipped?
19 Aug 2015
Because there is a switch that needs to be changed everytime whether the loco is leading or trailing which is located in the No.1 cab end - if the No.1 is next to the coaches then it will add time to the changing ends process (securing cabs etc..). It can and will probably happen at times but the general consensus is to keep it to a bare minimum.
EE Andy b1
12 Dec 2013
CLC
Right OK i understand.
So is this switch for basically isolating/connecting the Driving trailer and it's equipment via the Class 68s Multiple working system? So there is not two driving desks live at the same time.
ic31420
23 Aug 2017
Surely the desk key would do that?
My money is on some braking type switch .
fowler9
29 Oct 2013
I saw a pair of Trans Pennine 68's head out of Liverpool through Wst Allerton at about 22:05 this evening. Anyone know which ones they were? Seen and heard loads of light engine movements the last few weeks.
dilbertphil
28 Jan 2018
Number 1 cab has been requested to be the leading cab for 2 reasons. Firstly as the Mode switch to say if the loco is driving or trailing is far easier to access from number 1 and so will help with turnaround. Secondly it's for driver comfort as the number one end is far quieter especially when the ETS is switched on for the coaches.
pt_mad
26 Sep 2011
Heard it mentioned that 68027 was parked up at Gresty Bridge at the weekend in TPE livery however unable to confirm.
EE Andy b1
12 Dec 2013
CLC
That all makes sense, thanks.
sprinterguy
4 Mar 2010
Macclesfield
I was only asking as the previous deliveries have included them, 4 or 6 of them on the rear coupled to the DT
More accurately described as brake force runners rather than barrier coaches, though I recognise that the latter is commonly used as a catch all term for the vehicles, I'm not here to split hairs over the matter. It's surprising if it's suddenly been decided that the deliveries by rail don't require them.
EE Andy b1
12 Dec 2013
CLC
Not really, if during testing of the other sets and all the numbers add up, for brake force etc, then runners not required,
and as there out testing quite often now just with a class 68, vehicles must be ok to run.
They'll still be checked on arrival at the port and brake tested and running brake tests.
notlob.divad
19 Jan 2016
Why is it surprising? The mk5a have begun mainline testing on UK rails. Therefore the authorities must have determined that their braking systems meet the requirements of the UK network and so they can run without the need for the barrier/brake force vehicles.
mikemcniven
13 Aug 2016
Manchester
