gimmea50anyday
So what sort of stunts do they do at the east end of MCV?
Oops!!! Lol XD
I’ll blame autocorrect on my new iPad!
Does this mean that all the 802s will be accepted by 17 February?
Well nothing's cancelled so far according to Journey Check but one Scottish diagram is 3 coaches instead of 5 - or is this 185 vs 397 rather than 802?
And still short-forms on Cleethorpes... only indirectly related to this thread though.
Doubt there were 11 out today - at least one Airport/Liverpool to Newcastle was formed of 3 coaches instead of 5 today.
They'll certainly be more in use than the Class 397/MK 5sets with only 2 and 4 respectively in use daily, so that's more than these combined.Don't think all 11 are out today either looking at Journey Check
How many are due out daily from Monday? 14 or 15?
13 diagrams. 9 Liverpool-Edinburgh 4 MIA-NCL
Looking at RTT doesn’t the full Liverpool <> Edinburgh service not start until the May TT change? So even if the current known gaps are filled the full intended Dec 19 timetable still has a couple of gaps, especially in the early morning off Edinburgh?Still one short on Liverpool to Edinburgh then? How does that work?
By the way, to save a separate post, I also noticed on RTT there are a couple of new timing points shown for Chathill and Longniddry “APCO”, which is presumably “auto power changeover”? Is that working now?
I looked at the Edinburgh end of the route using a similar query, and it isn’t quite as “neat” at all up there. Does that mean most early arrivals at Liverpool haven’t done the full trip?If this is the line up of services from Liverpool to Edinburgh next week, the 0520 works the 1524 and everything in between goes to Edinburgh. I make that 10 cycles.
https://www.realtimetrains.co.uk/se...20-02-20/0200-0159?stp=WVS&show=all&order=wtt
It is true that some inbound workings to Liverpool aren't currently in RTT so maybe there will still be an Edinburgh bound train or two missing in practice.
Hi,
Does anybody know if any 802s will be in Manchester today between 11:30 and 16:30 please?
Thanks in advance.
A bit complicated today because of engineering work so there aren't many TP trains around Manchester today let alone 802s. In particular the Edinburgh to Liverpool service doesn't run west of Huddersfield (except the last one of the day).
http://iris2.rail.co.uk/tiger/rendercissod.asp?file=302470.xml&width=full&graphic=1 indicates that the residual Liverpool Lime Street to Manchester Victoria shuttle looks like it may be formed of 3-car 185s - certainly the 1025 from Liverpool shows as 3-car - check in an hour to see if the other unit is as well.
You might want to check http://iris2.rail.co.uk/tiger/rendercissod.asp?file=302492.xml&width=full&graphic=1 to see if any of the Manchester Piccadilly to Newcastle services are run with 5-car trains. By looking at York and Newcastle as well you may be able to work out which cycles have 5-car trains on them.
Yes, there is one arriving now in platform 2 at Piccadilly. (I think it forms the 11.40 to Newcastle). I used the TPE app under 'live times' to check.Hi,
Thanks in advance.
