childwallblues
Thank you.Great start
Thanks @ainsworth74. I'm sure discussion on the TRU will continue apace.Please see the existing thread on a proposed Skipton - Colne reopening. This thread is for the Transpennine Route Upgrade which does not include that reopening scheme.
A pessimistic betting.What's the betting that in ten years' time we shall still be travelling between Liverpool and Manchester and between Manchester and Leeds at average speeds below 60mph?
The alternative is the M62 car-park, so good luck getting anywhere close to an average speed of 60mph from city centre to city centre during daylight hours...What's the betting that in ten years' time we shall still be travelling between Liverpool and Manchester and between Manchester and Leeds at average speeds below 60mph?
Four tracks between Huddersfield and the (flat) junction with the L&Y line at Heaton Lodge, and then four tracks along that line right through to Wakefield, so well beyond the junction with the LNW Leeds line at Ravensthorpe. Two tracks thence to Leeds. But there was of course the Leeds New line which effectively gave four tracks all the way from Huddersfield to Leeds. There were the two routes into Leeds, via Whitehall Jn and via the later Viaduct Line into the Joint Station, but passenger traffic used only the Viaduct Line in from Farnley Jn.I'd put more money on a poor quality extended M65 towards Skipton than a genuine improvement of the TP rail routes.
Apols if this question has been asked before but how much of the line EAST of Huddersfield was historically 4 tracked pre the usual BR rationalisation? Standedge always gets mentioned but how much sustained 4 tracking could be had between Hudds and Leeds?
Thanks for that. I know very little about the railway over that side , is it straightforward to 4 track or are we talking similar to Wavertree Tech Park and Broad Green, Liverpool where there are breaches of the trackbed
In effect classic four track Huddersfield to Ravensthorpe Jn, with the two two-tracks routes on to Farnely Jn on completely different alignements, several miles apart from each other at the greatest separation. The old route was the one from Ravensthorpe Jn through Dewsbury to Farnley and then on to Whitehall Jn. The Leeds New Line (Spen Valley Line, opened 1900) on which you'll get full info from the source Wellhouse cites, diverged just before Heaton Lodge Jn, dived under the L&Y Calder Valley main line, and then headed off on its own route to re-join the older route at Farnley. It was also at Farnley that the Viaduct Line diverged to provide the connection directly into the Leeds Joint Station when that was built to join up the LNW and the NER in 1869.Thanks for that. I know very little about the railway over that side , is it straightforward to 4 track or are we talking similar to Wavertree Tech Park and Broad Green, Liverpool where there are breaches of the trackbed
I've always puzzled why Ravensthorpe only has platforms on the Leeds lines when the Wakefield lines are so near.You are of course correct, but even now, the other pair that diverges at Ravensthorpe goes to Wakefield Kirkgate and then Normanton to Leeds, giving a longer, but potentially higher speed route (although it is well below the potential max speed.
I'm not sure of the history of the decision, though as a station it struggles- being among the lowest used stations in West Yorkshire. There's no housing in the immediate vicinity, and AIUI a fair amount of the surrounding land is thought likely to be unsuitable for housing development due to contamination.I've always puzzled why Ravensthorpe only has platforms on the Leeds lines when the Wakefield lines are so near.
K
Yes, the original route of the Manchester & Leeds Railway. It could be a very high-speed route (if the original alignment at Healey Mills were restored). To get a really good impression of it, see Don Coffey's splendid cab-view video on YouTube.You are of course correct, but even now, the other pair that diverges at Ravensthorpe goes to Wakefield Kirkgate and then Normanton to Leeds, giving a longer, but potentially higher speed route (although it is well below the potential max speed.
The Micklehurst Loop was built as the quadrupling because it was not practical to provide the two additional tracks on the other side of the valley through Mossley. There was in effect a four-track railway from Heaton Norris Jn to Leeds if you take into account the alternative routes from Denton Jn to Stalybridge, from Stalybridge to Diggle Jn, and then from Heaton Lodge to Leeds.It is potentially 4 track all the way to Manchester as the 4 track continued from Huddersfield through Golcar, Marsden and standedge tunnel to Diggle where the micklehurst loop diverged and rejoined the route at Stalybridge. You then have your split to Man Vicc via Ashton and Man Picc via Guide Bridge. The formation is again 4 track between guide bridge through Ashburys along the former woodhead lines into Piccadilly.
Of course the viaducts along Micklehurst have now long gone but you can still see where the junctions were located at Diggle and in the mouth of Stalybridge Tunnel
I've just been reading Roger Ford's e-preview of his column in the March Modern Railways:
http://live.ezezine.com/ezine/archives/759/759-2019.02.18.03.45.archive.txt
His first item is on electrification costs, and it seems NR has been challenged to produce an electrification plan for the whole of the TP route, for the current estimate of the partial scheme cost (ie filling in Huddersfield-Stalybridge "for free" by saving the costs required ).
That is based on lessons learned from the recent overspends, and applying new design standards to the project.
The gist is that with these changes, costs should be £1.0-1.2 million per stkm* rather than the £2-3.5 million of recent NR schemes.
There is also scope to reduce future costs to the European average of £0.8 million/stkm (though I seem to remember reading words like that before, in the 2009 RUS).
A report is also due on 28 Feb about electrification costs. (RIA/DfT/NR).
A great read for us optimists.
Whether DfT will buy it for CP6 implementation is another story.
* stkm = single track km.
Station was on a LNWR line; Wakefield line was L&YR -- and that once had other stations closer to populated areas, e.g. Thornhill and two stations in Horbury.I've always puzzled why Ravensthorpe only has platforms on the Leeds lines when the Wakefield lines are so near.
K
Neither of which are in Leeds or Manchester city centres, so that's not really a fair comparison. Rail will never compare well to such a niche journey from one random market town to another random market town, and nor should it try. Especially if both towns are close to the motorway network.I commute 3 days a week from Chorley to Garforth over M62. There are bad and good days, but I average 1.5hrs each way.
On train, it'd be 2:15hrs (assuming everything ran on time).
I would hope future electrification costs are budgeted at around the average of recent NR schemes, with maybe a small variation depending on complexity, and this is only changed as NR demonstrate via projects completed under budget and on time. To agree a project based on £1.0-1.2 million vs £2-3.5 million would seem utter folly to me.
That's how publically funded projects often end up in ever increasing cost cycles. If it can be shown that costs can be reduced, and quite frankly we can see that costs can be considerably less, then the lower figure should be used when sounding out potential contractors. If you ask contractors to work to £2-3.5M then they will, plus any additional costs that might be found along the way. No contractor is going to initially accept that budget then come back at the end of the project & say it cost 25-40% less.
I'd be happy to wager that electrification costs could be brought much closer to those of our European neighbours if the DfT got a better handle on costs & future contracts. That could then mean full wiring of the TPE, along with potentially taking additional schemes back off the shelves. All that is required here is the political will, and an acceptance from the Minister & DfT that bi-modes are best used for routes were destinations are beyond the wires, not to fill in gaps because you've incorrectly forecast costs based on flawed project management in the past. Sadly this is where the real problem lies.
To my way of thinking, the main problem with costs of electrification projects is that too much other work is allowed to be included in the 'copper wire' account. The first is backlog of maintenance and can add millions of pounds putting the track to where the designers assume it should be given prudent maintenance - a concept designer doesn't need to know the detail to sketch out an overall scheme. The second is enhancements - these can add vast sums in terms of costs of material, disruption and time to pure electrification work. In some ways, Chris Grayling has done the right thing in pausing electrification into Bristol in order to get infrastructure and signalling work out of the way before the piles go in. Thirdly, signalling needs to be upgraded in order to cater for the electric environment causing more disruption and cost. Fourth is the fact that Britain suffers from being an 'early adopter' in that, when lines were built, there was no thought for the future to provide large clearances in case bigger trains were to be introduced - many lines would not have been built had it not been for the 'penny pinching' all those years ago.That's how publically funded projects often end up in ever increasing cost cycles. If it can be shown that costs can be reduced, and quite frankly we can see that costs can be considerably less, then the lower figure should be used when sounding out potential contractors. If you ask contractors to work to £2-3.5M then they will, plus any additional costs that might be found along the way. No contractor is going to initially accept that budget then come back at the end of the project & say it cost 25-40% less.
K
That's not what I meant, you are right of course potential suppliers should always be encouraged to put in their best offer and if the market is functioning they will. The client needs to be sure though the offer is realistic and not just an unrealistic number in order to win the job. Part of the functionality for the moment seems to me to, as you say, ensure a decent pipeline of work, but probably rather less than in recent times to allow companies to build up and get costs down without blowing the bank in the meantime. However to budget for things based on unattainable cheap rates is crazy and is probably the quickest way to lose any remaining confidence in electrification. Correctly forecasting jobs is based on what has been demonstrated and most certainly not on the assumed 'should be'.
If contractors can operate on an open book and be incentivised to share savings maybe they will. Or if they see they deliver under forecast, thanks to being for whatever reason more efficient with innovative ways of doing things, then good on them to keep that money and invest, they can then bid lower for future business and gain more work.
If a politician says please electrify the GWML to reduce carbon emissions, and give faster trains between Paddington, Bristol and Cardiff, there are many more questions to answer before an answer can be given regarding the cost.
If the electrification were to be examined in isolation, would the cost overruns be so eyewatering? We know what we want but to put all the ills of the past on the electrification budget is bad accounting, bad publicity and a could also be referred to as a dereliction of duty from politicians, managers, designers etc.
