Are TfW taking trainees directly into the Mainline links at Cardiff now?
Ever since Wales & West / Valley Lines it used to be you had to serve your sentence on the Valleys before you got to go Mainline.
Surprisingly enough, yes. They've recruited directly for guards for mainline in the past but I do believe this is the first time in many years drivers have gone straight to mainline.
That said, the bottom link on the mainline side of the depot isn't all that different from the Valleys - it's mostly trips to Ebbw Vale, Maesteg and around the VOG to Bridgend I believe. Not much class 1 work in there.
I wasn't given the option but live in merthyr so assume it would be valleys line. Would take either tbh. Have they given u a date for the medical yet
If you're application is specifically for Cardiff then your being in Merthyr shouldn't make any difference. Both the Valleys and Mainline depots are based out of the same building in Cardiff and where you live shouldn't come in to it. If you've applied for the other depots near to you however (Treherbert, Rhymney and the new depot at Taffs Well if they're recruiting for there yet) then you'll be on the Valleys network as those depots only work there.
