rd749249
- Joined
- 15 Sep 2015
- Messages
- 171
Newington
The Up Through went in November 1969. The Down was still in use in the early 1980s, but probably went around the time the box closed in May 1985 (not sure, though).Exeter Central through lines went some time ago didnt they?
No line actually through the station that does not have a platform face. The avoiding lines do not pass through the station area as the name implies.York
What are the through likes used for?I don't think Totnes has been mentioned - two through lines although nearly all passengers trains call. Dawlish Warren has been listed.
Did anyone mention Durham, one through line only.
Lol what I kind of meant was is it passenger services that pass through without stopping?I was assuming if Darlington was allowed above (see post #27) which has the same layout of through lines outside the ‘station area’ then so would York. In both cases the station areas are on lines diverged from the main running lines.
Trains which don’t stop at that station!
Could also be freight. See post #1.Lol what I kind of meant was is it passenger services that pass through without stopping?
Is that the same line mentioned in post #65?Chesterfield (Up direction only).
It's not the same situation. At Darlington trains are routed into either the platform or through lines at the same decision point. At York trains must diverge at Skelton Junction before getting to the station area.I was assuming if Darlington was allowed above (see post #27) which has the same layout of through lines outside the ‘station area’ then so would York. In both cases the station areas are on lines diverged from the from the main running lines.
HereWhere in particular? Generally through lines are used for all traffic not booked to call at a location whether it be non-stop passenger trains or freight trains which have no crew relief at that location.
The lines at Havant may well have been taken up to simplify the signalling/alignment for reversible working. Totnes has been left alone as there is no need to change it.The reason for wondering is that the through lines through Havant were taken up so I was kind of wondering why though lines at Totnes still exist.
At Hereford, the through lines are only used for freight trains, IIRC.Where in particular? Generally through lines are used for all traffic not booked to call at a location whether it be non-stop passenger trains or freight trains which have no crew relief at that location.
And also by steam tours to stable the train while the loco shunts to the dock for water.At Hereford, the through lines are only used for freight trains, IIRC.
I think you’re right, the provision of two sets of crossovers at each end of the station for full bidirectional working, ie facing and trailing, was done during the Portsmouth Area resignalling in 2007, and IIRC the one remaining through line was removed in 2006 as a precursor to the work..The lines at Havant may well have been taken up to simplify the signalling/alignment for reversible working. Totnes has been left alone as there is no need to change it.
Yes those are good ones! In terms of the Eastern Stratford used to have a number of through roads (including spurs) but not since the station was rebuilt a few decades back when the station's last remaining through track was removed.Don't think I have seen mentioned:
London Fields
Cambridge Heath
Bethnal Green (Overground)
Does it? I'm aware of the 'Down Hastings' line passing alongside Platform 2 and the 'Up Hastings' line passing alongside Platform 1 at Crowhurst. And that's it, unless very much mistaken. Might of course have been different in the past.Crowhurst
No you are right - my errorDoes it? I'm aware of the 'Down Hastings' line passing alongside Platform 2 and the 'Up Hastings' line passing alongside Platform 1 at Crowhurst. And that's it, unless very much mistaken. Might of course have been different in the past.
Can anyone confirm?
It used to have through lines, but no longer does. https://www.kentrail.org.uk/crowhurst_2.htm say 1971 for removal.Does it? I'm aware of the 'Down Hastings' line passing alongside Platform 2 and the 'Up Hastings' line passing alongside Platform 1 at Crowhurst. And that's it, unless very much mistaken. Might of course have been different in the past.
Can anyone confirm?
Must be long gone: Crowhurst B box closed in 1971.Does it? I'm aware of the 'Down Hastings' line passing alongside Platform 2 and the 'Up Hastings' line passing alongside Platform 1 at Crowhurst. And that's it, unless very much mistaken. Might of course have been different in the past.
Can anyone confirm?
Crowhurst did have centre through lines but they were removed when the track layout was reduced following closure of the Bexhill West branch.No you are right - my error
