Trivia: Towns which do not deserve the service they get
Schweir
16 Aug 2017
Several towns (e.g Crewe) appear to get far more services than the town requires principally due to the station also acts as a major interchange. Which other towns do you think are overserved in terms of services (can just be generally overserved (considering passenger numbers) or due to being an interchange etc...).
Of course this is an arbitrary topic so please justify your answer a little :)
Quite a number of the smaller stations on Merseyrail, e.g. Aughton Park, Town Green, Little Sutton, Overpool and probably most obviously Capenhurst-in-the-Sticks. These are served at quite high frequency simply because Merseyrail is primarily a simple all stations operation (though Capenhurst only gets half the Chester trains).
Manchester Airport, where used as a terminus of convenience. If Picc had 6 platforms facing west I reckon it wouldn't get a number of the Northern services.
Mojo
7 Aug 2005
Tamworth, Macclesfield
Retford
MidnightFlyer
16 May 2010
I hate basing train service provision on population, and it desperately needs obliterating as an argument in its own right for adding, or removing, services to certain places.
With all that said, Barnham does phenomenally well in the context given by the OP. It even has a traincrew depot for good measure!
Mag_seven
1 Sep 2014
here to eternity
I would agree with that as things like easy access to motorways that improves accessibility to the rail network are important factors e.g. Parkway stations.
Megafuss
5 May 2018
Spalding
Controversial, but I say Ely. I accept it is more down to geography, but Bury St Edmunds is twice as big and has less than half the service.
gnolife
4 Nov 2010
Johnstone
Corrour, Falls of Cruachan, Loch Eil OB and Locheilside all do remarkably well in terms of service relative to population, if I'm not mistaken, none of them have a house within a mile.
DynamicSpirit
12 Apr 2012
SE London
Dovey Junction doesn't do too badly for a station that serves virtually zero population and, apparently, has about 12 entries/exits per day ;)
higthomas
27 Nov 2012
A lot of the sorts of places that are gonna get a worse service after HS2 and be up in arms about it. Stoke, Coventry, Stafford etc.
ANDREW_D_WEBB
21 Aug 2013
Epping, with a population of less than 12000 has a very frequent service 7 days a week on the Central Line
tbtc
16 Dec 2008
Reston City Centre
I agree that "population" can be a frustrating tool to use in debates about the level of service that a place should receive (especially as some places have artificially lower/higher populations due to municipal boundaries, some places act as "rail heads" for larger areas etc - so Bradford looks important because the population numbers include Ilkley/ Keighley etc whilst somewhere like Alfreton can look small but is the long distance station for the much larger Mansfield).
(and, in many cases, it makes more sense to stop every train on an hourly frequency at each station rather than have an "every four hours for some stations, every three hours for some stations, every two hours for other stations" approach - sometimes simplicity is worth over-provision - especially as you then get into the complicated issue of whether doubling back should be permitted if not all intermediate stations are served on each service etc)
But (putting population to one side) it'd be interesting to compare the number of services stopping at a station each year with the annual passenger numbers at that station to see which stations are under/over-served in terms of services stopping there.
For example, I worked out on the back of an envelope that Manchester Airport received around thirty three passengers departing on each service that stopped there - that sounds like a low number (compared to the length of trains stopping there) but maybe that's quite high compared to most stations - I don't know how easy it'd be to fiddle around with the data (e.g. on Real Train Times) and compare it to the widely available annual passenger stats - if anyone has a fag packet to do the calculations on?
coppercapped
13 Sep 2015
Reading
I agree that "population" can be a frustrating tool to use in debates about the level of service that a place should receive ...
SNIP
Sorry, can't help...don't smoke! 8-) :)
adrock1976
10 Dec 2013
I'm surprised that nobody has mentioned Stoke Gifford yet.
Although it is (I believe) a church parish in the southern extremity of Gloucestershire, Bristol Parkway station is close to the motorway and also provides interchange between the London trains and the Intercity Crosscountry network as well as local trains to Filton Abbey Wood and various Avon and Somerset destinations.
Mikey C
11 Feb 2013
Beckton on the DLR
That branch is still comparatively lightly used other than by ExCel visitors, and very quiet when you get to the final station
Mugby
25 Nov 2012
Derby
Corby has been lucky to get it's hourly service to London. I imagine some departures carry only penny numbers of pax.
dk1
2 Oct 2009
East Anglia
I often think that. For all the fuss they make about the place inc electrifying the branch, the usage figures are nothing to shout about. Nothing but talk of future growth since day one.
Sleepy
15 Feb 2009
East Anglia
Manningtree - 3 trains per hour off peak is unnecessary when non - Harwich connecting trains see 5 or less pax normally.
dk1
2 Oct 2009
East Anglia
Hopefully that will be resolved in the upcoming timetables. Much of it is down to branch connectivity but Norwich passengers will shed no tears about passing through at 70mph.
Dr Hoo
10 Nov 2015
Hope Valley
Having used Corby station today (as I quite often do), what makes you say that? Obviously the trains to or from London are less busy than they are at Luton but the same goes for most (effective) ‘end of the branch’ stations. I certainly wouldn’t say it was penny numbers.
Vast housing developments continue. The place has doubled in population in the time I have known it and it has become far more outwardly focussed.
dk1
2 Oct 2009
East Anglia
You only have to look at the usage figures. The growth has been pretty poor even dropping with what is a very good service. They are still around or less than 300k pa which even makes Great Yarmouth look good over the same period.
