TSC
Gareth Hale
11 Jun 2005
What lovely 158 sounds, it really reminds me of been on the Leeds to Burnley line 8)
Is it me, or do I hear sombody saying Whats-up in the idle loop sound :oops:
Jim
11 Jun 2005
Wick
Has anyone noticed that when it whines (power to notch 0) there is some distict coughing in the background.
I love this version, as my pet 158 (746) whines beatifully when it slips :oops:
class 313
10 Dec 2005
St Albans
220 is lovely! just drove it on the ECS 6 car timetable on maybank and its nice! :D cant wait for that hst :D
evil_hippo
9 Jun 2005
Lewisham
I heard coughing....
(perhaps it was Harold)
29 Jul 2005
Above about 120 mph, all the sounds on the voyager go totally distorted on my pc :( any ideas why? Well done on a couple of fantastic updates anyway!
andrewmay
8 Jun 2005
West Midlands
An excellent update to the 158 with very realistic sounds and the 220 is also fantastic. Great work TSC and keep it up.
29 Jul 2005
Coxster said:
It was slightly updated on the 28th.
Unfortunatly that hasn't helped my sounds problem. Is that what the update was meant to fix? All sounds above about 120 mph are distorted, including passing noises of other trains. This seems to me as if there is a problem with either the route file or my sound card...? Is there some kind of specific audio codec i need or something? What do you reckon?
Muppet
7 Aug 2005
In a Box
Theres a new picture of the HST and it looks like the update of maybank as well. which could be released this week. :D
wumpty
20 Jul 2005
Deepest Darkest Brum
Hi,
Glad you like the new stuff. Stay tuned ;)
The updates today will fix the gauge lighting on the Voyager, after some feedback I've had it confirmed it should be blue. The update to the 158 fix a bug with the stop/start buttons and remove the cough from the engine wind down sound.
Lanky, I can only imagine the sound problem to be down to graphics or sound card drivers. I know that some machines will crash BVE when you go above 100mph as they can't cope with the processing required to more frequently process the sound and graphics, so might be worth trying any sound card driver updates you can find...
Or you could turn down the hardware acceleration on your sound card settings to see if that helps:
Start Menu/Settings/Control Panel/Sounds and Audio Devices/Audio/Sound Playback
- Click advanced, then Performance and drop the hardware acceleration notch by notch and see what happens.
Nitro
20 Nov 2005
Hello wumpty I am also having problems with the new voyager :( Every time I load it BVE crashes when it gets to the sound.cfg or panel.cfg and I get an error message. It only works on one route and thats Plymouth-St Austell. Im probably having graphics card problems yet the new Class 66 workes perfectly. Any help is appreciated.
EDIT: I tried what you said to lankylancaster and it works!!! The Voyager finally works and its a beauty :P
29 Jul 2005
wumpty said:
Hi,
Thanks Steve! I turned the hardware acceleration completely off and it worked! And what a train it is! Nothing like bombing along maybank at 140 mph! ;)
29 Jul 2005
Just thought I'd ask as to how the buzzer works on the voyager. Do you need to reply back to the 1st 3 beeps as well as the 2 after, or just the 2 after. Also, I know it might seem like a silly question but do drivers on voyagers normally go straight to P7 full power from standstill or would they go to say P3 until there is movement before full power?
Muppet
7 Aug 2005
In a Box
ill do it in beep form.
[Gaurd] beep. beep beep.
[Driver] beep. beep beep.
[Gaurd] beep beep.
[Driver] beep beep.
hope this helps. :)
29 Jul 2005
Wow, that was quick, yes that helped a lot thanks. And from what I gather, the driver must close the doors after the 3 beeps? But obviously this can't really be modelled on BVE.
Coxster
9 Jun 2005
Voyagers and Meridans do not have notches - they are continuous. Unfortunately that isn't possible in BVE though.
bunnahabhain
8 Jun 2005
Actually they are notched, I believe they are E, B5, B4, B3, B2, B1, N, P1, P2, P3 and P4.
Nick
8 Jun 2005
[Gaurd] beep beep.
[Driver] beep beep.
hope this helps. :)
Why is the guard telling you to set back? I thought the first 3 beeps were the DDA requirements on the Voyagers (as heard on Meridians) to warn people they were closing the doors. I am not a fan of the Beep buzzer, I prefer a noticeable Buzz Buzz. But anyway, you shouldn't reply to the first three set back beeps and then not do anything and await a Right Away.
Regarding Meridian throttles, Jamies correct. Presumably the same on Voyagers...
Ca55ie
30 Jun 2005
The beeps are actually more like 1-2. This is the signal from the train manager to the driver, who has control of the doors, to shut the doors. Once the interlock has been proven etc, the train manager sends another 2, to tell the driver to get going.
Sam
heart-of-wessex
11 Jun 2005
Trowbridge
yes its a 1-2 beat not a 3 beep, beeeep. beep beep (clear to close doors) driver responds with 3 beeps and closes doors
66526
9 Nov 2005
They have markings on the CPBC so that you can guage yourself. It's like with 47s. The throttle handle only has notch "on" and "off" but there are markings for 1/4, 1/2, 3/4 and full. It is notchless from "on" but the markings are just there for the driver to guage himself. 8)
Guinness
13 Jun 2005
The Beep Beep - Beep means the Guard requires the driver to close the doors, its in the BR Guard to Driver Code. Hence why Steve said needs to update the Plug in for the Driver to close the doors as opposed to Guard (See the readme). 2 Beeps means Ready to Start. The Driver need to repeat the beeps to acknowledge.
The 3 x 3-Beeps using the Minus Key (-) means that the Guard needs to contact the Driver via the intercom.
See: http://www.rodge.force9.co.uk/faq/bellcodes.html
HTH
