Under consideration
TRain87
1 Sep 2016
England
Evening all
Just called Network Rail to find out the recruitment procedure. Once your application is submitted, if your answers go past the required benchmark, your application is 'under consideration' - but I was just informed that they look through all internally applicants first, before looking at mine! Do they not advertise the job internally first, then if that don't receive interest they then advertise externally? As you can tell, I'm rather impatient, and I know this is a long process lol
Cheers for any help
RBSN
14 Jul 2014
Evening all
Just called National Rail to find out the recruitment procedure. Once your application is submitted, if your answers go past the required benchmark, your application is 'under consideration' - but I was just informed that they look through all internally applicants first, before looking at mine! Do they not advertise the job internally first, then if that don't receive interest they then advertise externally? As you can tell, I'm rather impatient, and I know this is a long process lol
Cheers for any help
Hold on to your hat buddy. It can take months to land a job. I was told that they do indeed recruit internally first, however, at the moment Northern are needing a lot of people. So I'd guess they will recruit from both 'pools'.
TomBoyd
2 Sep 2013
Unless you're going to work for ATOC, you're not going to work for National Rail. And this is important to get right if you go through to interview. You need to know the company you're applying to, and you need to know about the job you're applying for.
